Second Floor Addition Over Existing 1st Floor. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-10-2009, 01:57 PM   #1
Second floor addition over existing 1st floor.
I am planning on adding a second floor over an existing one story home. The existing foundation is for a first floor only. There is no basement.
I would want to keep the first floor as intact as possible. I am thinking that ther may be a way to float the second floor over the first using pads and beams and or removing stucco and reinforcing exixting exterior walls if needed. I need to use the existing foundation foot print as there are restrictions.
This home is in Los Angeles.
Is there such thing as a frame that can support the 2nd floor that acts as a foundation for it?
handball is offline   Reply With Quote
Old 02-10-2009, 02:08 PM   #2
I would think LA is in an earthquake zone?
If so you will need engineered plans
If you need the same footprint then you need a staircase in there somewhere. An engineer would be able to design any beams as needed based on the existing house
Anything here would merely be a guess since we don't know your house
Installing floating floor over squeaky wood floor- rip it up? (Q3) cee2ski Flooring 1 02-09-2009 07:23 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
Hardwood Floor Painting Advice / Tips / Tricks? cherie Flooring 3 09-05-2008 10:52 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
