Search For Lineals - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-01-2012, 10:50 AM   #1
Search for Lineals
I am looking for a company that manufactures black 3 1/2 inch lineals. I also want black skirting. Anyone know of such a company? I have seen this on some houses but I have been unable to locate online.
LolitaV is offline   Reply With Quote
Old 04-01-2012, 10:54 AM   #2
Framing Contractor
What's a lineal?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 04-01-2012, 12:32 PM   #3
Rewards Points: 12,886
Do you mean lintel? It's what's used to support block or brick over a wall opening.
Lowes, Home Depot, and concrete supply house, steel supply will have them.
No clue what you mean by black skirting. When you say skirting all I can think of is what's used around the bottom of a mobil home.
Old 04-01-2012, 12:35 PM   #4
Rewards Points: 268
Can you describe what you are looking for? Or provide a picture?
packer_rich is offline   Reply With Quote
Old 04-01-2012, 01:15 PM   #5
Lineals
Lineal is a name I have seen used for moulding around windows and doors. It is used on the Certain Teed Vinyl siding website.
Old 04-01-2012, 01:18 PM   #6
Go back on there web site and look for where it says "where to buy"
Any siding distributor that carry that brand can get it for you. Just look in the yellow pages under siding.
Still have no idea about the black skirting.
Old 04-01-2012, 01:21 PM   #7
Skirting
Sorry what I mean by this is the part that is the exposed basement portion of the house. We currently have a stucco coating on cement blocks. And the upper portion of the house is stucco. I am changing the upper portion to vinyl and want wide window trim (lineal) and beaded board or batten (skirting) below the vertical vinyl siding. The stucco overcoat on the cement block is starting to come off.
Old 04-01-2012, 01:22 PM   #8
Problem
the problem is they dont have black.
Old 04-01-2012, 01:33 PM   #9
MarginallyQualified
Rewards Points: 2,464
buy some paint
Old 04-01-2012, 02:35 PM   #10
Rewards Points: 1,294
You generaly won't find vinyl siding material made in black
danpik is online now   Reply With Quote
Old 04-01-2012, 04:28 PM   #11
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,010
are you sure you dont mean "architrav". as in fancy headers
woodworkbykirk is offline   Reply With Quote
Old 04-01-2012, 04:58 PM   #12
kwikfishron's Avatar
Rewards Points: 92
A lineal is 3 ˝” or even 5 ˝” channeled window or corner trim that has it’s own starter strip. It only comes in 20’ lengths that I’ve ever seen.
I doubt you’ll find it in black, there’s been to many problems with dark vinyl colors.
You may be able to find black coil or gutter stock and create your own if you must have black trim.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Tom Struble (04-01-2012)
Old 04-01-2012, 05:55 PM   #13
Cant understand
We just drove through a new area of the city and there are lots of houses with the black trim. Had the hubby with me and he thinks it may be tin, so I will check for that now.
Old 04-01-2012, 06:45 PM   #14
kwik is right. more than likely its painted.. most trims of that nature come in white then its painted to the homeowners liking
Old 04-01-2012, 08:27 PM   #15
Painted
Painted with what, I live in an area that gets extreme temperatures from 40 Fahrenheit to -50 Fahrenheit. Any suggestions on paint, I was hoping to go maintenance free. I may have to just be happy with white.
How to Search the Message Board with Google enos Site Help and Suggestions 0 03-12-2012 03:39 PM
Webmaster and Search hits m1951mm Site Help and Suggestions 1 08-20-2011 08:00 AM
Advertising blocking search function YerDugliness Site Help and Suggestions 2 12-21-2009 07:20 PM
Why does the search exclude words jamiedolan Site Help and Suggestions 4 12-27-2008 08:01 AM
search this forum doesn't work ? Scott_K Site Help and Suggestions 2 12-11-2005 09:13 PM
