Sealing Vapor Barrier. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-08-2007, 10:36 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
Sealing vapor barrier.
I'm insulating my house using Owens Corning pink insulation with Kraft paper. Is there a tape that I can use to seal the gaps between the insulation batts. I'd like to have as complete a vapor barrier as possible.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 10-08-2007, 10:52 AM   #2
Where is the insualion be installed? (walls, attic, basement...)
redline is offline   Reply With Quote
Old 10-08-2007, 12:07 PM   #3
I have gas!
The insulation is in the stud bays of walls and ceiling.
Old 10-08-2007, 09:31 PM   #4
you could try the tape used to connect wrappings of insulation for hvac ducts, its expensive tape though.
JFD140 is offline   Reply With Quote
Old 10-08-2007, 09:38 PM   #5
Rewards Points: 150
"tuck" tape... that's the brand name and it's designed to tape different materials together and will maintain a vapour barrier... although I'm curious, is Kraft paper still used (to code) as a vapour barrier?
slakker is offline   Reply With Quote
Old 10-08-2007, 10:09 PM   #6
yummy mummy's Avatar
Rewards Points: 1,016
I used "tuck" tape. It is red in colour, but I did not use the kraft paper faced insulation.
Mine was the pink batts in between the studs and then a plastic vapor barrier over the insulation, 6 mil., and then I used the tuck tape to seal all the joints.
yummy mummy is offline   Reply With Quote
Old 10-09-2007, 06:05 AM   #7
I have gas!
Is kraft paper lined insulation not widely used anymore?
Old 10-09-2007, 06:37 AM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Kraft-faced insulation is still widely used by insulation manufacturers as a vapor retarder for insulation. It is considered by ICC and all other inspectional codes as a rated vapor barrier.
Owens Corning Website info: http://www.owenscorning.com/around/i...iling_tip.html
Vapor barrier/retarder info: http://en.wikipedia.org/wiki/Vapor_barrier
- Build Well -
Sealing Brick Pavers sflamedic Painting 9 04-11-2011 09:17 PM
Sealing Concrete J. V. General DIY Discussions 4 10-04-2007 03:19 PM
Driveway sealing ... $100 bucks... worth it? KUIPORNG Landscaping & Lawn Care 14 08-17-2007 02:08 PM
HELP! Screwed up sealing bathroom floor plum Flooring 4 03-28-2007 09:03 AM
sealing garage floor rl10851 General DIY Discussions 4 04-03-2006 12:13 PM
