-   -   Sealing vapor barrier. (http://www.diychatroom.com/f19/sealing-vapor-barrier-12199/)
Clutchcargo 10-08-2007 11:36 AM
63 Attachment(s)
I'm insulating my house using Owens Corning pink insulation with Kraft paper. Is there a tape that I can use to seal the gaps between the insulation batts. I'd like to have as complete a vapor barrier as possible.
redline 10-08-2007 11:52 AM
Where is the insualion be installed? (walls, attic, basement...)
Clutchcargo 10-08-2007 01:07 PM
63 Attachment(s)
The insulation is in the stud bays of walls and ceiling.
JFD140 10-08-2007 10:31 PM
you could try the tape used to connect wrappings of insulation for hvac ducts, its expensive tape though.
slakker 10-08-2007 10:38 PM
"tuck" tape... that's the brand name and it's designed to tape different materials together and will maintain a vapour barrier... although I'm curious, is Kraft paper still used (to code) as a vapour barrier?
yummy mummy 10-08-2007 11:09 PM
I used "tuck" tape. It is red in colour, but I did not use the kraft paper faced insulation.
Mine was the pink batts in between the studs and then a plastic vapor barrier over the insulation, 6 mil., and then I used the tuck tape to seal all the joints.
Clutchcargo 10-09-2007 07:05 AM
63 Attachment(s)
Is kraft paper lined insulation not widely used anymore?
AtlanticWBConst. 10-09-2007 07:37 AM
Kraft-faced insulation is still widely used by insulation manufacturers as a vapor retarder for insulation. It is considered by ICC and all other inspectional codes as a rated vapor barrier.
Owens Corning Website info: http://www.owenscorning.com/around/i...iling_tip.html
Vapor barrier/retarder info: http://en.wikipedia.org/wiki/Vapor_barrier
