Old 08-28-2006, 05:19 PM   #1
seal8682's Avatar
Send a message via AIM to seal8682 Send a message via MSN to seal8682 Send a message via Yahoo to seal8682
Default Sealing a Standard Doorway
Hello, I am a college student and I live in a converted garage room, last year I was having trouble with rain coming in through a door that is in back of the room, it is old and raggedy and insects constantly come in, I would like to remove the door and install a wall where the doorway is. It is 6'1/2" x 2'1/2" x 5". I have no idea why the people who converted the garage installed the door but I never use it, if anybody can give me some tips on what I need or a procedure to install a wall where the doorway is, I would greatly appreciate it, rainy season is coming up and I would like to get the it done by then, again thanks to anybody in advance for any information
seal8682 is offline   Reply With Quote
Old 08-28-2006, 07:07 PM   #2
Home Improvement Guy
ron schenker's Avatar
I would suggest you talk to the landlord first before you do anything. He may...
1) say no
2) volunteer to do it
3) pay you to do it
4) let you do it for free
Obviously option 2 or 3 would be nice
Either way, make sure you stress the fact of why you feel it's important to make this change
ron schenker is offline   Reply With Quote
Old 08-28-2006, 07:28 PM   #3
seal8682's Avatar
Thumbs up Ready to go
O.K. thank you for the suggestion Ron , I just talked to the landlord and she was kind enough to give me permission to make the modification, since the agreement between me and my landlord was that I was to maintain my room at my cost since I am paying very little rent since she knows I am a student. I've already done some minor fixes in the room and it is much more liveable now than it was before. She was nice enough to offer to pay half of whatever the cost is to seal the doorway so now I'm looking forward to doing this. Thanks again Ron.
Old 09-05-2006, 06:58 AM   #4
If this is the second doorway into the living space it may be required by code as a emergency exit. I would check before closing it off. A replacement door may be the better choice.
Zero Punch is offline   Reply With Quote
Old 09-05-2006, 07:17 AM   #5
seal8682's Avatar
Default it meets city code
Thanks for the reply zero, my landlord and I checked last week to see if it was alright with the city. Since it is actually the third door in the Room it is alright to seal it. I am thinking to seal the doorway I have to construct a frame of wood around the doorway for base and put crossing 2 x 4's for support, I just thought of this off the top of my head, so if anybody can tell me if I'm on the right track I'd appreciate it. Thank You
Old 09-06-2006, 08:31 PM   #6
Just a suggestion, when you are putting in your door, why not add a keyless entry? I just added 1 to my garage door, and it works really nice. I got my keyless entry at www.thekeylesslock.com. So, now i got a question, say for example, my doorhole from deadbolt to latch is 3 1/2'', and I want to put a lock in there that's 5 1/2'', I drilled the hole on top, does that make my door weaker? and how would i make it so that my plate can fit?
handyjoe is offline   Reply With Quote
More On This Topic
So, the question is often posed, do I approach the bagua from an overall perspective of my entire home? Or should I look at the individual corners that are happening in a room? Well, that's a really good question and there is no hard and fast answer to... Read More »
Garage Remodeling Summary
Garage Remodeling Summary by Expert Village
Hi! This is John on behalf of Expert Village in this video clip I will be talking about our garage project. In the beginning of our garage project we had masonry block walls what we did we framed in those walls and we put up insulation. The reason for... Read More »
On behalf of Expert Village, my name is George Engle with Mr. Fix-It Handyman here in Miami, Florida and today I am going to be showing you how to install weather stripping on the exterior of your garage door. Okay, pretty much put an even bead across... Read More »
Whether you need a garage for your vehicle or extra storage it will be a wise investment for your home. The plans for a garage can be purchased off the Internet instead of using a high priced architect because of the simplicity of the design. If you want... Read More »
Hi, this is Jon and in this clip we will be caulking our joints. For this step I'm going to be using a window, door and siding type sealant. Now these come in tubes that fit into caulking guns, which allow you to apply it to your surface. If you cut the... Read More »
Considering widening interior doorway - How difficult? davewolfs Remodeling 11 05-23-2007 03:26 PM
Need to Cement Up old Basement Doorway BigArnold Building & Construction 1 12-29-2006 05:52 PM
American Standard or Trane lilvree HVAC 1 02-07-2006 01:22 AM
constructing a hidden doorway bubblehd Building & Construction 1 10-15-2005 04:13 AM
how to-create doorway in load bearing wall Nikkil Building & Construction 1 05-17-2005 01:06 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
