Sealing Slab For Moisureproofing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 08:40 PM   #1
Sealing slab for moisureproofing
Hello,
I'm new here. I built a custom home in 2004. I have excessive moisture entering into the basement and shop areas. I live on a hill in a forrested area where moisture and humidity is excessive. The basement area is 750 sq. ft. and I have to use a dehumidifier to get rid of the excessive moisture or it gets a mold smell. I was gone for 2 months, came home , turned on the dehumidifier and filled the bucket which I believe is around 3 gallons in 1 day just in the basement area(waste of electricity). Can this problem be solved using redgard or bluegard? If so, how do you use it? I currently have carpet down there, do I need to pull the tack strips? or will that matter if I leave them there and go around? I am looking for an answer only from someone qualified to answer or someone who has the experience. Thanks.
bryank1 is offline   Reply With Quote
Extending Patio Slab and adding a cover Jeoroc24 Building & Construction 5 04-12-2011 12:16 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
Concrete Slab - Sealing AndrewF Building & Construction 1 08-08-2009 06:05 AM
questions on sealing slab , underlay pad, double padding under laminate pauls Flooring 8 02-21-2009 02:10 PM
