Sealing Rim Joists For Water - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 07:07 PM   #1
Sealing Rim Joists for water
Hello -
Remodeling a basement and have noticed some water coming in from the still plate. I have begun to fix this with spray foam and will seal with silicone as well as make sure the outside is correctly sealed.
There is one other place that I have noticed water damage on the rim joists. along with making sure all outside joints are sealed I want to seal from the inside. Using silicone is had due to the space constrains.
Was thinking on using the roofing cement/tar that I could use a brush to reach in the corners.
Is this something that work or should I seal with silicone and insulation?
indhoosier06 is offline   Reply With Quote
Old 02-17-2011, 08:06 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,638
I donno,... I think I'd stop the water from the Outside, 'n let it dry out to the inside....
A run of flashing, whatever it takes to keep the water Out...
Old 02-17-2011, 10:31 PM   #3
Registered User
Rewards Points: 526
As Bondo said, divert the outside water with metal first, then inside- use foam board and canned foam to keep the basement air from condensing on it; http://www.buildingscience.com/docum...m-at-rim-joist
Gary
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 05:28 PM
Double floor joists harsuwind Building & Construction 3 09-15-2010 07:35 AM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 05:43 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
