Sealing Protrusions In Foundation Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 06:11 AM   #1
Sealing protrusions in foundation wall
I have a few protrusions for my gas line, hose bib, and sump line that run through my poured concrete foundation. All 3 holes are above grade and were covered with putty by the builder since 03. I noticed that the carpet tack strip directly underneath those areas is slightly rusted indicating some water getting in or condensation between the wall where the cold and warm air meet.
What's effective way to fill those protrusions in? I was thinking Great Stuff expanding foam, which states that it's water resistant if water indeed is the culprit.
cobrakai is offline   Reply With Quote
Old 11-20-2011, 06:43 AM   #2
There are a number of products that will do the job, urethane foam is one, polyurethane caulk is another. There are a variety of cement and epoxy based putty type products that also work. Whatever you use, force it back into the hole so it surround pipes, crevices, etc. Some of these products don't work well on a damp surface.
Old 11-20-2011, 07:12 PM   #3
Great stuff is also prone to ultra-violet rays from the sun
mrgins is offline   Reply With Quote
Ok to insulate the top of hollow concrete brick foundation wall? creamaster Building & Construction 3 10-28-2009 08:43 PM
Cutting into foundation wall to install entry door. notenoughtime Building & Construction 7 08-19-2009 02:13 PM
Water in crawlspace, dug out too close to foundation, How to fix? Build a wall? twilightcall Building & Construction 6 05-18-2009 09:16 AM
How important is plastic vapor barrier on foundation wall? slatergrl Remodeling 5 02-18-2008 12:49 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
