Sealing Post With Paint On Bedliner. Your Thoughts? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 09:31 AM   #1
Sealing post with paint on bedliner. Your thoughts?
I am building a pole barn in a fairly wet area of bottom land. I was thinking about painting the post with the new bed liner that they have available far added protection. What do you think about this? And by fairly I mean very wet!!!!!!
markcrain is offline   Reply With Quote
Old 08-22-2011, 08:22 AM   #2
AGWhitehouse's Avatar
Never heard of it being done. Does that stuff even stick to wood?
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-22-2011, 08:34 AM   #3
fabrk8r
fabrk8r's Avatar
What post? Posts that support the structure?
If they are support columns I'd prefer that they stayed out of the ground, and standing water, by attaching them atop a concrete footing that goes from below the frost line to above the water line.
You have to remember that if you seal wood so water can't get in, it will also prevent moisture from escaping if any does happen to get behind the sealant.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-22-2011, 09:34 AM   #4
Experienced
Jackofall1's Avatar
As Fab stated, if its that wet install Sonitubes to complete a concrete foundation below the frost line and then fasten the post on top so you don't expose the wood to excessive moisture.
But to answer the question I wouldn't use a product designed for steel truck bed on a wood post buried in the ground, products are designed per thier functionality, using it outside its intended application will yeild unknown results.
Given the implecations of failure I would not risk the unknown.
Mark
Old 08-22-2011, 10:28 AM   #5
I had considered that but then I have to concern myself with the building racking unless I use diagonal bracing. I'm also poor as a field mouse. I'm sure it will stick to wood and I had seen a company that sells 4x6 posts with a plastic dipped end. Thats what gave me the idea.
Old 08-22-2011, 10:36 AM   #6
kwikfishron's Avatar
Rewards Points: 824
You could just tar the bottom portion of the post. Even if it would work that bed liner stuff isn’t cheap.
kwikfishron is online now   Reply With Quote
Old 08-22-2011, 10:40 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,976
Have you consdered using post brackets in the concrete? Simpson makes a lot if different styles.
You embed that in the concrete....once the concrete is cured, you attach your posts. That way, if a post goes bad on you...easy to replace.
Compressor terminal post wiring connector came apart - remnant still sticking to post justplumducky HVAC 11 07-06-2011 08:04 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
Paint recommendations and finish questions EJacobs Painting 2 09-03-2008 10:38 PM
