Sealing House Vent? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2010, 08:52 PM   #1
Rewards Points: 24
Sealing house vent?
My brick home was built in 1956 and has a 4 inch house vent that leads into the crawlspace. My furnace has its own direct outside air supply. My house has just been tested for its tightness. It is 54 on a scale of 1-100. With suggested renos I can only get it to 58. So the house is inherently leaky. Therefore I am wondering if I must just as well seal the house vent. Any comments?
giannit is offline   Reply With Quote
Old 01-13-2010, 05:53 AM   #2
They make thermostatically controlled(mechanical) crawl space vents that help. They open at 70 deg and close at 40 deg, or in that range.
Old 01-13-2010, 06:33 AM   #3
Does the vent go from outside to crawlspace, or inside to crawlspace.
Normally you have a number of vents outside to the crawlspace, but you don't want any from the inside.
pyper is offline   Reply With Quote
Old 01-13-2010, 07:35 AM   #4
Rewards Points: 24
Sealing house vent?
Pyper,
The vent is in the crawlspace wall and vents to the outdoors. The crawl space is dry with a concrete floor and there has never been any hint what-so-ever of moisture or mold.
I get the impression it should be sealed in the cooler weather and open in the warmer weather.
Old 01-13-2010, 11:11 AM   #5
If you only have a single vent, it's probably not doing anything from a moisture standpoint anyway. If it was my house I'd close it off and monitor things -- closely for a year and sporadically after.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Sealing off outside old electric stove vent frescocat HVAC 1 01-12-2010 08:54 PM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 10:01 PM
Proper way to install half round dormer vent? Git Roofing/Siding 12 07-31-2009 05:33 PM
EXcessive moisture in house geema HVAC 5 09-10-2008 11:18 AM
