Sealing A Foundation Gap? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 07:38 AM   #1
Rewards Points: 97
Sealing a foundation gap?
I have a sizable gap between my foundation and my concrete patio. I'm concerned that bugs and water will find its way inside my house. How and what can I use to seal it? I have no idea how deep that gap is either. The gap is about 1" wide and spans the length of the concrete patio (5-6feet I think).
edta1 is offline   Reply With Quote
Old 06-07-2011, 01:03 PM   #2
Rewards Points: 5,336
Has the gap size remained the same over time or has it gotten bigger? A 1" gap is not usual for that situation.
Ron
B. Franklin 1759
Old 06-07-2011, 01:34 PM   #3
Rewards Points: 97
I don't know. I just bought the house. I was going to seal it with expandable foam (Great Stuff). That stuff turns hard like a rock though. So if the concrete expands and contracts due to weather (I'm in Chicago), would it hold? How flexible is Great Stuff foam?
We are getting some bug problems. So right now I'm just looking to seal whatever I can.
Old 06-07-2011, 08:25 PM   #4
Rewards Points: 162
I would pick up some 1" foam backer rod and insert it along the length of the crack depressed about 1/2" from the surface. Use a good self leveling caulk on top of the backer rod for a seal.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 06-07-2011, 09:56 PM   #5
Great Stuff is an inappropriate material for this. As Stubborn suggests, backer rod and a self leveling material. I use a product from the Sika company. There are others. It's sold in home Depot and comes in 2 caulking sizes and 2 colors(tan and gray).
Any mason supply will also carry this product type.
Key to a good installation is a backer rod size that is tight to both sides or the material will flow past and disappear.
Sides need to be clean and dry.
Ron
B. Franklin 1759
Old 06-08-2011, 07:37 AM   #6
Rewards Points: 97
Ok, thanks! do I have to stuff the foam all the way down and try to fill up the gap? Or just filling it at the surface is fine? I have no idea how far down this goes.
Old 06-08-2011, 08:25 AM   #7
concretemasonry's Avatar
Rewards Points: 2,626
edta -
I think stubborn1 said to get the apprpriate width for your crack and push it down (it will fit tighly) to allow a required amount of sealer over it. The depth depends on the width of the crack.
The idea is to create an amount of caulk to move and stretch with the seasonal and daily movements of the two concrete elements without letting go or tearing.
Make sure you get the proper caulk and if you a shop for materials by price, you will be doing it again after you have cleaned everything out. Preparation and cleaning of the gap is neceesary and critical.
Dick
concretemasonry is online now   Reply With Quote
Old 06-08-2011, 12:58 PM   #8
Rewards Points: 97
Thanks Concrete,
I understand what stubborn1 is saying, but I guess I should have asked, do I need to fill the gap? If the gap is 6 inches deep, should I keep stuffing it with more and more foam back rod until I get the appropriate depth?
How should I clean the gap? It's outside. Just spray with water, let it dry for a day, then stuff the gap with foam back?
Old 06-08-2011, 01:02 PM   #9
You should not have to fill the bottom of the gap.
For cleaning, a good hose followed by some drying and then a good blowing to get any dust/fines out followed by more drying time, especially if the caulk required a dry substrate for proper adhesion.
Just like painting - preparation is the secret to success.
Dick
Old 06-08-2011, 03:52 PM   #10
The point of the backer rod is to limit the amount of material you use and at the same time, get enough material into the crack to seal it.
Ron
B. Franklin 1759
Old 06-08-2011, 04:25 PM   #11
I guess I missed the main point is that you want enough material to stretch between the slabs and not be adhered to the soil below. If the rod is not the appropriate amount for the joint width, it will not work properly.
Dick
Old 06-08-2011, 04:40 PM   #12
Rewards Points: 4,738
closed-cell backer rod is used to limit the sealant's depth so it will maintain proper adhesion AND cohesion,,, sika's a good mtl for this whether you use the self-leveling or non-sag types,,, IF you use the non-sag ( ns ), tool ( push down ) w/a teaspoon to force sealant against the clean sides of the joint thus promoting proper adhesion.
stadry is online now   Reply With Quote
The Following User Says Thank You to stadry For This Useful Post:
concretemasonry (06-08-2011)
Old 06-10-2011, 12:51 PM   #13
Sometimes due to soil conditions, the slab is not tied to the building's footing to allow for extraction and contraction of the soil and movement of the slab and preventing cracking. I would make sure you use some expandable material to allow for it to still move and don't make it rigid.
luckattack is offline   Reply With Quote
Old 06-10-2011, 02:24 PM   #14
slabs are NEVER tied into structures - be it a building, foundation, or roadway/bridge,,, proper sealant means 1 has picked mtl w/the proper exp/contr qualities IF its installed in the proper depth:width:thickness ratio,,, that's why there are product sheets showing HOW to use it correctly !
Sealing pipe through block foundation kboorman General DIY Discussions 22 04-13-2015 07:51 PM
Need help sealing foundation leak (townhouse) RickDel Building & Construction 17 02-07-2012 03:25 PM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
Sealing concrete foundation around water pipe shtoink Building & Construction 9 09-18-2009 05:15 PM
Sealing a concrete wall foundation richvoice Building & Construction 7 11-25-2008 02:55 PM
