Sealing Exterior Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-11-2009, 01:00 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 508
Sealing exterior door
I installed a new exterior door between the garage and house. I am getting ready to seal between the jamb sides and the frame. I want to know, expanding foam, insulation, or caulking? Or some combination of those - I am hearing conflicting things...
J187 is offline   Reply With Quote
Old 01-11-2009, 04:41 PM   #2
Rewards Points: 5,336
You could use low expanding foam, or fiberglass insulation on cracks wider then 1/4". If the crack was less then 1/4", you could use caulk.
Ron
Old 01-11-2009, 05:00 PM   #3
Remodeling Specialist
Ditto. I chalk around the garage side moldings before installation, fiberglass around the jamb and then chalk underneath the interior trim with latex chalk.
I only use expanding foam when I can control its expansion as not to force windows or doors out of alignment.
Baron is offline   Reply With Quote
Old 01-11-2009, 05:40 PM   #4
J187's Avatar
Rewards Points: 508
Thanks, I caulked the brick moldings before nailing the unit unit, so that's done. I used construction adhesive between the threshold and the concrete sub. I guess I'll use insulation around the jambs - thanks. What a big improvement over the hollow core interior door with a sheet of tin stapled to the back and no insulation or caulking that used to be there.
Grout lightened after sealing SueT Tiling, ceramics, marble 6 11-23-2008 09:58 PM
Sealing basement marly General DIY Discussions 1 11-21-2008 04:09 PM
sealing up air leaks between troyce1 General DIY Discussions 2 10-15-2008 09:14 AM
Sealing Concrete J. V. General DIY Discussions 4 10-04-2007 04:19 PM
Driveway sealing ... $100 bucks... worth it? KUIPORNG Landscaping & Lawn Care 14 08-17-2007 03:08 PM
