Sealing Exposed Board? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-06-2012, 11:57 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 818
As part of our 2-story addition....I will be installing a 2x12 rough cut cedar board on one side of the house....
The board is going to go down the side of the addition....basically about level between 1st & 2nd floors (about where those 2 thin lines are)
The board will be used to attach wrought iron brackets to so that my wife can train her wisteria to grow across them.....
The rest of the wall will be stucco (I already have the weep screed and flashing worked out)
I am going to stain the board with Watco Dark Walnut oil stain.....
So...what is the best way to seal that side after the stain has had time to dry? We want a dull look....needs to look rustic English (seeing how my wife is English)
All the stuff I normally use is for indoor....typically semi or high gloss.
Tung oil is out of the question...won't last in the weather....
Thompsons?
edit....just realized I should have put this in painting.....Jim? Care to move it?
ddawg16 is online now   Reply With Quote
Old 10-06-2012, 01:05 PM   #2
I'd just use some kind of ext. oil stain like deckscapes semi transparent.
Tham
Tham is offline   Reply With Quote
New control board or fix it? Bobeht HVAC 26 01-18-2012 04:03 PM
Fascia board install - unlevel rafter tails giperbolic Roofing/Siding 3 01-18-2012 12:46 AM
Covering exposed foamboard. Anything options besides gypsum board? strategery Insulation 7 12-10-2011 08:55 AM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 02:16 PM
How do you ground York furnance control board garryshaf HVAC 11 01-24-2010 01:06 PM
