Sealing Concrete Foundation Around Water Pipe - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-17-2009, 09:34 PM   #1
Wounded Mathematician
shtoink's Avatar
Sealing concrete foundation around water pipe
Hi
I have just run a water line from my cistern through my concrete foundation into my crawlspace. What is the best way to seal around the pipe to prevent water from entering the crawlspace? I am in coastal BC, Canada, so below ground freezing is not a big problem.
See photo:
The poets have been mysteriously silent on the subject of cheese.
G.K. Chesterton
shtoink is offline   Reply With Quote
Old 09-18-2009, 04:57 AM   #2
Rewards Points: 4,656
dig down 6" BELOW the penetration, clean wall, then coat w/roofing cement,,, apply 6mil pvc sheet membrane press'd into the soft cement, then coat w/another layer of cement,,, be careful w/backfill that no rocks/sticks ruin your work,,, also realize the soft backfill will allow water to flow down.
if you don't do this right, you can always inject hydrophyllic polyurethane grout from the inside
Old 09-18-2009, 04:57 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Ayuh,... Pack it with Grout...
Old 09-18-2009, 07:43 AM   #4
Registered User
Termite's Avatar
Yeah, I think the roofing cement idea would work but I think it is gross overkill.
Hydraulic cement (hydroplug) is a waterstopping cement product you can buy in small dry mix buckets at home centers. Mix it to the consistency of peanut butter and pack it in the annulus around the pipe from both sides. It will make a very tight and watertight seal. This is how it is done in new construction as well as situations like yours. Basic cement mix will probably shrink as it dries and will not be as effective, so make sure you get hydraulic cement.
Old 09-18-2009, 09:36 AM   #5
shtoink's Avatar
Thank you, gentlemen!
G.K. Chesterton
Old 09-18-2009, 04:35 PM   #6
ohmigawd, the moderator said ' annulus ' 'mite, the reason i suggested that method's because we've seen too many hydraulic attempts fail,,, a supporting reason is we'd only want to do the job once,,, callbacks hurt your credibility & we saw too many jobs which didn't go ALL the way to resolve the leaks.
that's not to say there isn't a space for hydraulic cement - it would work outside but only maybe & that's not good enough for us,,, now go wash your mouth out w/soap
Old 09-18-2009, 04:43 PM   #7
shtoink's Avatar
I'm not sure I'd want a hydroplug anywhere near my annulus.
I have a little bit of leftover roofing cement and some poly so I might try that method first anyway.
Thanks again!
G.K. Chesterton
Old 09-18-2009, 04:44 PM   #8
Civil Engineer
Rewards Points: 4,790
I used expanding foam (Great Stuff) with good success when I put a 2 inch pipe for a sump pump through my concrete basement wall. Its been 15 years with no problem. I also used silicone caulk on one penetration, ten years with no problem. I have never used hydraulic cement for sealing a penetration, not saying it wouldn't work, but I am not sure how easy it would be to pack it into a deep space, like a 6 inch thick concrete wall.
Old 09-18-2009, 04:48 PM   #9
forgot all about that ' stuff ', dan, but your discharge's only gravity & there's not a whole helluva lot of head pressure there - especially if your discharge's above grade as are most,,, as w/most waterproofers, we're VERY aware of our annulus, too .
Old 09-18-2009, 05:15 PM   #10
Registered User
Termite's Avatar
Try to give some sage advice and all I get is sarcasm.
Maybe "gap" is more acceptable?
water running down waste pipe rav927 Plumbing 5 07-04-2009 09:24 PM
Water in crawlspace, dug out too close to foundation, How to fix? Build a wall? twilightcall Building & Construction 6 05-18-2009 09:16 AM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 06:54 AM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
