Sealing Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 06:33 PM   #1
Sealing Concrete
I'm going to be sealing my concrete driveway and patio soon and was wondering if anyone had any brands of sealer they would recommend. Also I was wondering if anyone had any input on the below questions. The colored stamped concrete was done about 60 days ago.
Should I use a water based sealer or a solvent based sealer?
Should I mix in some slip resistant grip in the sealer?
Can you add color to sealer to slightly change the color?
Any help would be appreciated.
bsmith95610 is offline   Reply With Quote
Old 08-01-2011, 10:46 PM   #2
I've used several brands over the years and unfortunately my opinion is that they are all the same. There is some company in Australia that apparently is "the best" but I can't remember their name... Something like si-2 or some chemical sounding name. I was able to get a sample and it seemed the same to me.
mchugh2001 is offline   Reply With Quote
Old 08-02-2011, 05:13 AM   #3
Rewards Points: 4,800
its difficult to beat eliteCrete's methyl-methacrylate reinforced ' CSS ',,, we apply 2 coats cut 1.5xylene:1 css w/1hr reapply window,,, solvent-based sealers are generally heavier-duty than water-based,,, we use sher-wms tints to color sealers
Old 08-02-2011, 02:49 PM   #4
Concrete & Masonry
Rewards Points: 636
Didn't the contractor apply the first sealer already? If so, you need to know what they put on to make sure it's complimentary.
Solvent ALWAYS works better on stamped concrete IMO.
If it's currently unsealed, first coat directly out of pail, second coat get's "grip" added to it.
Yes, but I'd suggest doing some test sampling first.
As for a brand, I've used several with similar results. I'd suggest going to a local ready-mix supplier to see what brands they carry. I've never seen a sealer available at a retail store that was worth the gamble of vandalizing a beautiful job over.
jomama45 is offline   Reply With Quote
Old 08-02-2011, 03:12 PM   #5
NACE Coating Inspector
mustangmike3789's Avatar
jomama45 answered everything very well. not knowing your location makes it pretty difficult to suggest a specific product. im not a big fan of the H&C products sold at home depot and sherwin williams. some places i would look into would be PPG/Porter paints, ultracrete, sure crete design and probably the product mentioned by itsreallyconc above
mustangmike3789 is offline   Reply With Quote
Old 08-03-2011, 01:02 PM   #6
Thanks for the info. I think I'm going to buy it from a concrete store in the Sacramento area called Spec-West. They have a solvent based High Gloss sealer. I'm going to try adding in the no slip stuff in the 2nd coat like you suggested. Thanks for this tips I appreciate it.
Old 08-05-2011, 01:47 PM   #7
Rewards Points: 192
I'm interested in the same thing and looked up eliteCrete. I was wondering if you could provide an average, ballpark, estimate for a 2 car driveway that's about 40 or so feet long. Are we talking hundreds or thousands to do this?
Thanks!
wiz561 is offline   Reply With Quote
Tags
concrete , sealer
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 05:42 AM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 12:06 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
Sealing old concrete floor alliekat Flooring 1 09-14-2010 09:52 AM
Sealing Concrete Pavers Kyle Landscaping & Lawn Care 2 06-26-2008 08:35 PM
