Sealing Between Stoop And House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-29-2010, 09:50 AM   #1
Sealing between stoop and house
What should we use to seal between our brick stoop and the brick face of our house? Will the Sikaflex construction sealant at Home Depot do the trick or something else? thanks!
smoochas is offline   Reply With Quote
Old 08-30-2010, 11:23 AM   #2
Rewards Points: 4,748
it will if its installed correctly over backer rod & not exceeding the depth:width recommended ratio
Exterior Stoop / Stairs joside Building & Construction 3 04-16-2010 01:37 PM
Wood decking over concrete stoop? spaceman spif Carpentry 2 10-23-2009 11:45 PM
Fixing a Sinking Concrete Stoop traderm Building & Construction 4 05-04-2009 06:34 PM
Crack in Concrete Slab under the Front Door diy4life Building & Construction 4 04-08-2009 09:11 AM
removing/replacing concrete stoop jmilana Building & Construction 3 03-11-2008 02:21 PM
