Sealing Around Kickout Flashing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-13-2007, 08:57 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,286
sealing around kickout flashing
I'm having trouble trying to figure out how to get the house wrap around the kickout flashing. Before I start siding, I need to get this resolved. We had wind driven rain last week so it was a good opportunity to see where I need to spend some extra time. Any ideas are always appreciated.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 10-13-2007, 11:16 PM   #2
Rewards Points: 5,336
What's kickout flashing?
Ron
Old 10-14-2007, 07:40 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Not sure what you mean by "Getting the house wrap around the kickout flashing"?
On siding areas where there is the opportunity for snow and ice build up (like a kick-out flashing area), lower dormer sidewall, etc..., you should use water and Ice membrane.
- Build Well -
Old 10-14-2007, 07:41 AM   #4
Ron
http://www.thehomeinspector.com/Clie...t/Kickout.html
- Build Well -
Old 10-14-2007, 07:42 AM   #5
I have gas!
It's the first piece of flashing in a roof to wall transition. It prevents runoff from the roof from draining behind the siding.
Old 10-14-2007, 08:36 AM   #6
I have gas!
Thanks Atlantic, What I was did was cut a slit in the house wrap and dropped it over the kickout flashing. It didn't really give me a water tight seal. I'm going to use rubber membrane to give me a better seal then I don't need to be so precise with the house wrap.
Do architectural shingles really work with step flashing? Malcolm Roofing/Siding 7 05-02-2008 11:31 PM
Plumbing vent flashing FatAugie Roofing/Siding 7 08-24-2007 09:30 PM
sealing a flashing boot johnny331 Roofing/Siding 3 07-13-2007 08:40 PM
Flashing problems Slave Building & Construction 3 11-16-2005 04:56 PM
