Sealing Around Copper Water Supply Line - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-21-2009, 11:31 AM   #1
sealing around copper water supply line
Water is leaking into my basement around the copper water supply line that comes in thru a poured concrete foundation wall. I am addressing the grading and drainage on the exterior of the house and I am going to seal around the copper pipe. I have consulted with two well credentialed companies; one recommends polyurethane injection and the other recommends bentonite clay. I have tried to thoroughly research both products but I am not having luck with determining which will adhere best to the copper pipe which expands and contracts. Has anyone out there had a similar situation and what product did you end up going with? How long has it been and is it holding up well or deteriorating? Thanks.
dazedanconfused is offline   Reply With Quote
Old 09-21-2009, 09:00 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,088
Ayuh,... Just plain ole Grout...
Old 09-21-2009, 09:30 PM   #3
Civil Engineer
Rewards Points: 4,706
I do not understand your comment about the copper pipe expanding and contracting. If you are on well water, the temperature of the water will be essentially constant year round, i.e. no change in the dimensions of the copper pipe. If you are on city water, there will be minimal change in temperature of the water, same conclusion about explansion of the pipe. The only way that pipe will undergo significant change in dimension is if you lose all the water in it, not likely.
That said, you can seal with grout, clay, polyurethane, or expanding foam (Great Stuff). I like expanding foam, easy to seal the entire annulus around the pipe. It does not matter if the product adheres to the pipe, as long as it fills all the space, it will be watertight. I used foam on a two inch sump pump line through an 8 inch concrete wall, has worked fine for 15 years. I also sealed one line using hydraulic cement, that worked well also.
Old 09-22-2009, 12:18 AM   #4
Registered User
Termite's Avatar
Careful Daniel, I used the word annulus the other day in another thread and they dogpiled on me for it. The word gap might have been more their speed I guess!
I'd use hydraulic cement (hydroplug). It is an excellent waterstop for this application.
Old 09-22-2009, 04:55 AM   #5
Rewards Points: 4,586
ANNULUS AGAIN ? ? ? exterior we'd use couple layers of roofing cement & pvc sheeting,,, interior, injectible polyurethane hydrophyllic grout,,, even tho the other respected posters describe success, i've seen too many failures,,, great stuff's a better choice than hydraulic to me.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Switch from 1/2" to 3/4" main water line? SanDiegoGuy Plumbing 10 04-17-2009 07:12 AM
water coming up water supply liner candaneh Plumbing 3 03-30-2009 09:50 AM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 10:53 PM
