Sealer For Gap Between Brick Facing And Garage Door Openings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 02:16 PM   #1
Question
Sealer for gap between brick facing and garage door openings
I have a house with brick facing on the front side. Where the brickwork meets the 2X6s that frame the garage doors, there is a substantial gap that was caulked many years ago. That caulk has deteriorated and needs to be replaced. The gap is really too big to use a regular caulking gun and I'm not sure what product I should use to seal between bricks and wood. Any ideas, fellows?
mgill30 is offline   Reply With Quote
Old 10-08-2011, 02:50 PM   #2
Rewards Points: 5,336
Expanding foam. You can get either the large gap stuff or the minimally expanding stuff.
If this for air stoppage from the exterior?
Ron
B. Franklin 1759
Old 10-08-2011, 05:51 PM   #3
Gymschu's Avatar
Rewards Points: 838
Ron is on the money. Use the minimal expanding foam. Let it dry good after it expands out of the gaps. Trim it back with a utility knife then apply caulk over the foam. If done right you will never know there's foam in the gaps.
Gymschu is online now   Reply With Quote
Old 10-08-2011, 11:26 PM   #4
Registered User
Rewards Points: 5,514
Closed-cell poly backer rod and caulk will allow movement with the two different materials and give you a bond break yet still stop air and water entry. Spray foam won't give you the required shape needed behind the caulk for the optimum "hour-glass" shape needed for movement. Page 35: http://books.google.com/books?id=XHA...0break&f=false
Scroll down to “Little details”: http://www.coastalcontractor.net/article/117.html
“Borrowed” this from one of our members….. http://www.masterwall.com/files/mw14...lantdesign.pdf
Page 30 covers caulking also; http://books.google.com/books?id=fDs...age&q=&f=false
Gary
Cooling the Garage steveKane HVAC 9 09-02-2011 02:31 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Insulation in Garage Attic ? SaDan Building & Construction 2 05-09-2010 05:44 AM
