Old 09-19-2009, 09:24 PM   #1
dIYHell
To seal or not to seal tops of IPE
I was planning on using Mesmers to seal both the ends and tops of my IPE deck boards. Just heard from someone who has done alot of installations and says I should only seal the cut ends and the sealing the tops is a bad idea because the seal won't absorb and you''ll get weird staining patters that will require sanding the whole deck down. I heard of this from others as well. anyone have experience with this.
rocketdoctor is offline   Reply With Quote
Old 09-19-2009, 11:39 PM   #2
Moderator
Termite's Avatar
Cut ends of ipe MUST be sealed with anchorseal. Otherwise they'll end up checking at the ends (cracking) due to moisture loss. Anchorseal is available from most deck suppliers. Stain/sealer is not an appropriate product for end grain sealing.'
I've had great luck with Penofin on ipe. Works great. Fact is you can seal the ends and not do anything to the rest of the boards and they'll last decades. They'll just weather down to a silver-gray color.
Old 09-20-2009, 12:25 AM   #3
dIYHell
heard about anchor seal. Did you use Penefin hardwood transparent hardwood on IPE, I would much rather use a finish to preserve the darker color instead of letting it go grey
Old 09-20-2009, 01:04 AM   #4
Moderator
Termite's Avatar
Yeah, I've just used the transparent Penofin (natural?) as opposed to a tinted version. It gives it a nice rich wet look.
seal a polished marble bathroom floor? tarheelblue Flooring 21 01-12-2012 12:58 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 09:14 PM
To seal or not to seal........ luce Flooring 1 05-18-2008 08:00 AM
Stink'n mice -- garage door seal... RippySkippy General Discussion 6 03-03-2008 04:11 PM
