Seal/caulk Garage Concrete Floor To Asphalt Driveway? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 03:53 PM   #1
Rewards Points: 324
seal/caulk garage concrete floor to asphalt driveway?
Hi,
There is a small (0.5 inch) gap between the garage concrete floor and the asphalt driveway. Water filters down the gap. What is a good flexible product to seal off the gap?
Thanks!
tigerbalm2424 is offline   Reply With Quote
Old 02-14-2011, 08:38 PM   #2
Rewards Points: 1,532
"You want to be carefull about not letting to much on the sand fill to wash out."
Why this advice? Sand hasn't been mentioned as a fix.
THere are flexible sealants that come in a caulking tube that will bridge fairly wide gaps that would work for this I would think. Typically need to fill the void with foam rod (flexible foam spaghetti-like strands that come in various diameters) and then apply the sealant. HD has one type; there are likely more and better choices at a local masonry/building supply dealer.
bob22 is offline   Reply With Quote
Asphalt patch/fill/seal with concrete involved brokenknees Building & Construction 1 10-29-2010 03:30 AM
spider cracks in garage foundation and concrete ramp up into garage alhippy Building & Construction 1 08-29-2010 11:48 AM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Building garage with elevated concrete floor dmj245 Building & Construction 13 05-31-2006 05:13 AM
Garage Concrete Slab...HELP? Aqua-Man Building & Construction 2 06-17-2005 02:11 PM
