Old 07-04-2006, 08:06 PM   #1
Screws vs Nails in Interior framing project
Hello, I'm constructing a doorway and partition for my fridge - I'm moving it from the kitchen and into the bedroom through the ajoining wall. For the framing portions of this projects, I was intending to use 3" screws for several reasons:
1) I'll be working in some tight spaces where hammering will be difficult.
2) I expect a goof or two along the way and would like to be able to unscrew the mistake and make whatever corrections are needed.
3) placing new studs in existing walls can be difficult when pounding it with a hammer - I'm working solo on most stages of this project.
But I've read on other forums and other places on the internet that screws are not up to code for framing construction - they made it sound like absolutly no screws are to be used - only nails.
I know there is a wide variety of screws out there. I'm considering using 3" DeckMate screws since they have the square drive head that reportedly won't strip. The sign at home depot said they are suitable for outdoor construcion. Shouldn't they be suitable for interior construction? Do you agree?
What's the advantage and disadvantage of screws and ditto for nails? Will building inspectors really give you grief for using screws instead of nails?
Thanks!
Alex
alexz is offline   Reply With Quote
Old 07-04-2006, 11:10 PM   #2
renovations
Screws have very low shear strength which is why they are not recommended for structural framing, however, it doesn't sound like you're doing any structural stuff. If the wall you are removing/moving is not weight bearing then go ahead and use what you want IMO.
Bonus is offline   Reply With Quote
Old 07-05-2006, 06:58 AM   #3
General Contractor
joasis's Avatar
Generally speaking, screws are not used in framing due to shear, as bonus said. However, we use GRK fasteners that are superior to any I have seen, and we now use them exclusively when setting trusses since we can screw up through the double plate into the truss. They are torx head, gold in collor, and you should be able to find them. The real beauty of them is you can drive and remove them many times..re-usable...
joasis is offline   Reply With Quote
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 08:08 AM
window installation - nails or screws mt232 Building & Construction 2 04-07-2007 08:41 AM
Drywall - Nails or Screws? digthisbigcrux General Discussion 6 03-20-2007 05:31 PM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 08:51 PM
