Screws Vs Nails For Deck. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-18-2013, 11:39 AM   #1
Screws vs Nails for deck.
Wanted to get opinions on using the Simpson screws for my deck hangers or should I just stick with nails?
Screws would seem easier to adjust if needed.
dabeast is offline   Reply With Quote
Old 10-18-2013, 11:51 AM   #2
cortell's Avatar
Rewards Points: 504
Assuming the particular hanger says it's OK to use the SDS screws, it's really just a matter of preference. For sure it's easier to remove a screw when you realize the hanger is in the wrong place. However, the screws are more expensive. Also, some people (me) find it faster to use a palm nailer to install the hanger than to use an impact driver. So, if you don't make (many) mistakes and you want to save money, and possibly time, nails are the way to go.
cortell is offline   Reply With Quote
Old 10-18-2013, 12:16 PM   #3
Rewards Points: 45
I was always taught to use nails on the hangars and screws on the deck boards. The shear rating on nails is so much higher than screws, less chance of your joists coming down once you have load on top.
RunningSparky is offline   Reply With Quote
Old 10-18-2013, 12:32 PM   #4
cortell's Avatar
Rewards Points: 504
Not true for Simpson SDS screws and other screws that are equally rated for structure. Typically, they are made of the same grade steel and have the same core diameter as common nails. Thus they have the same shear strength.
Old 10-18-2013, 12:36 PM   #5
Didn't even think of a palm nailer. I don't own one and this will be a good reason to purchase one. Use nails with a new tool would probably be about the same cost as using screws probably.
Suggestion on what palm nailer to purchase?
Thanks,
Old 10-18-2013, 12:44 PM   #6
cortell's Avatar
Rewards Points: 504
Thanks,
It'll be love at first try. You'll wonder how you ever got by without one.
I use Dewalt's (D51180). I'm very happy with it, but good luck finding one. Dewalt discontinued them and they have not introduced a replacement model. I had to buy mine second hand on ebay.
I've heard good things about the Bostitch one, and the price is pretty reasonable. I believe either HD and/or Lowes carries them. They do around here, anyway.
Old 10-18-2013, 02:35 PM   #7
Think i'll go with the Bostitch one it will give me something to use my Lowes gift card on.
Old 10-18-2013, 02:37 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
Understatement......about the only negative is the noise...those b!tches are loud....wear ear plugs and enjoy the results.
I have the Bostich....$37 from Amazon
http://www.amazon.com/BOSTITCH-PN50-...ds=palm+nailer
Old 10-18-2013, 02:47 PM   #9
Rewards Points: 13,732
I have two Bostitch palm nailers that have worked out fine.
We were using so many hangers nails I went one step further and bought a nailer that uses hanger nails in a strip.
Talk about faster, any of you pro's that use a lot of hanger nails I strongly suggest buying one.
cortell (10-18-2013)
Old 10-18-2013, 10:08 PM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,212
the screws are spec'd specifically in seismic zones i beleive as they are harder to pull out
woodworkbykirk is offline   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
hand drive (10-19-2013), Windows on Wash (10-19-2013)
Old 10-28-2013, 11:08 AM   #11
Just wanted to say thanks for the suggestions on the palm nailer. It woked great this weekend as I was building my deck.
Sent those nails through the wood like a hot knife through butter.
The Following User Says Thank You to dabeast For This Useful Post:
cortell (10-28-2013)
Nails Vs. Screws For Ceiling Furring Strips emagsamurai Building & Construction 3 11-30-2012 02:57 PM
Screws or nails in dbl layer of OSB soggycashew General DIY Discussions 6 02-18-2012 01:38 PM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 08:56 AM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
