Screws, At Times, Won't Go All The Way Through - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-28-2006, 09:24 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Screws, at times, won't go all the way through
I am using 2 1/2 inch screws on my 2X4s, and at times, not all the time, I have a problem getting them all the way through.
They seem to go a certain distance and then will not go any further, no matter how hard I try, either with drill or by hand, (even my husband has tried).
So what I end up doing is unscrewing it, drilling a hole and then screwing it back in.
I am wondering why this is happening?
Am I encountering a knot in the wood?
Is there any way that I can avoid this?
I also have tried using a nail instead, and also same problem, no matter how hard I bang with the hammer, it will not go all the way through.
Any thoughts on this?
Or will I have to drill a hole first, whenever I encounter this difficulty?
Thanks a bunch
yummy mummy is offline   Reply With Quote
Old 11-28-2006, 09:32 PM   #2
concretemasonry's Avatar
Rewards Points: 2,654
Wood is not as uniform as everyone thinks. - Differences in moisture, density, residual sap, grain orientation, etc.).
I don't think you or the screws and nails are any different.
concretemasonry is offline   Reply With Quote
Old 11-28-2006, 11:05 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
THat way I use a impact driver, drilling 3" screws are a breeze.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 11-29-2006, 05:31 AM   #4
Are you hanging drywall with the 2 1/2 screws? (Use shorter screws)
If you need to use 2 1/2 screws then try to screw it in half way. Back out the screw and then screw it back in. This is a shorter method then drilling a pilot hole.
You could also try rubbing the screw threads with a bar of soap before you install them. This will lubricate the threads and reduce the resistance.
redline is offline   Reply With Quote
Old 11-29-2006, 08:22 AM   #5
redline
No, I am not yet hanging drywall.
I am still at the framing stage.
Will try your suggestion, but I think I will have to end up drilling a hole.
Old 11-29-2006, 08:23 AM   #6
ron the plumber
What is an impact driver?
Old 11-29-2006, 08:48 PM   #7
Master Craftsman
Big Dave's Avatar
Sounds like you might be using a fine thread screw instead of a course thread screw. I've had trouble with fine thread screws not going in all the way and stripping out.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 11-29-2006, 09:06 PM   #8
big dave
I think I am using a fine thread screw.
Those were the ones that they gave me when I asked them for what purpose they were for.
I am going to try some other ones, and see if that works.
Today, I tried drilling a pilot hole and that worked really nice.
But rather time comsuming.
Thanks for the tip, big dave.
Old 11-29-2006, 09:18 PM   #9
big dave
I just took a look at your web site, big dave, and your work is amazing.
Very nice.
Love your floors, and countertops.
Old 11-29-2006, 09:18 PM   #10
Journeyman Plumber
Do a google search for impact driver.
Old 11-29-2006, 09:24 PM   #11
ron the plumber
I just looked impact driver up, and seems like a great tool, but probably too expensive for a newbie like me.
Old 11-29-2006, 09:26 PM   #12
Journeyman Plumber
If you ever get the chance use an impact driver, you will sure love it.
Old 11-29-2006, 09:27 PM   #13
ron the plumber
I bet I need a lot of strength for it, correct?
Old 11-29-2006, 09:30 PM   #14
Journeyman Plumber
Not at all, you can run screws running the driver with one hand, very little pressure need applied.
Old 11-29-2006, 09:33 PM   #15
ron the plumber
If I tell my husband that I want another tool, he is going to have a fit.
He says I don't need anymore fancy tools, because I don't have a time limit.
(Actually, my aunt felt sorry for me, when she found out I was cutting 2X4s with a hand saw, and bought me an early Christmas gift of a mitre saw.
I absolutely love it. I have never used one before.
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Purpose of square black washer on outlet cover screws? darsunt Electrical 3 07-20-2007 10:27 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
