Old 07-17-2009, 09:37 PM   #1
screws or nails
anyone have opinions on using screws or nails for flooring? by flooring i mean the sheeting directly on the joists. iv heard that the constuction adhesive does all the work and that coated nails are fine. some say ring shank nails, and some swear by screws. any advice or opinions are appreciated.
thanks,
john
roadhouse is offline   Reply With Quote
Old 07-17-2009, 10:00 PM   #2
screws or nails
these or something like it. it used to be a question of tinsel strength. nails used to have more but some of the newer specialty screws have the same if not more strength. plus always easier to unscrew then rip nails out. get yourself an impact driver / glue down an go to town.
http://www.dhcsupplies.com/store/p/2...s-2-to-3-.html
-Brian
lemon714 is offline   Reply With Quote
Old 07-17-2009, 10:15 PM   #3
screws or nails
but is there anything wrong with using coated nails? i could nail it in about a quarter of the time. its 30'x52', thats a lot of screwing.
Old 07-17-2009, 10:19 PM   #4
screws or nails
there is no problem with nailing at all with the coated nails. make sure you use ring shank. it really just boils down to what your more comfortable using
Old 07-17-2009, 10:32 PM   #5
screws or nails
Construction adhesive and 8D ring shank nails for 3/4" subfloor. Preferably with a pneumatic nailer and a compressor.
Ron
Old 07-18-2009, 12:35 AM   #6
screws or nails
gotta be a ringed shank nail. Glue and screw. Or glue and nail. In my opinion, they are equal.
the carpenter is offline   Reply With Quote
Old 07-19-2009, 07:07 PM   #7
Moderator
screws or nails
For years I used a ring-shank nail, until the screw-shank nail came along. It actually turns 1-1/2 times (8d) as it goes in or out, not wrecking the wood fibers punching a hole as the ring-shank. I never went back as I had less squeaks. When you set the deck ply, let it down- not flop and drop. The glue bead flattens to 1-1/4+" wide, almost worthless. Start nailing from the center of sheet outwards while standing on it.(No air pockets) Be safe, G
Old 07-19-2009, 09:50 PM   #8
screws or nails
well, i finished the floor today(started this morning) and i went with 8d ring shank nails with construction adhesive. seems pretty good to me. everything went pretty smooth (other than having to stop for a couple of hours to dig for my drainage pipe). thanks for the advice and im sure ill be asking for many more opinions. john
underlayment for stick on tiles or vinyl novice40 Flooring 7 09-03-2008 05:49 PM
window installation - nails or screws mt232 Building & Construction 2 04-07-2007 08:41 AM
Drywall - Nails or Screws? digthisbigcrux General Discussion 6 03-20-2007 05:31 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 08:51 PM
