Screws For IPE Decking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-08-2009, 12:14 AM   #1
dIYHell
Rewards Points: 150
Screws for IPE decking
Im installing an IPE deck and planning on fastening from the top with Stainless steel screws. This will give the desired look as well I believe a more stable attachment.
Ive been planning on predrilling but some people have mentioned screws like SplitStop that supposedly you don't need predrilling. Anyone have experience with these screws or other recommendation for Stainless Steel deck screws?
rocketdoctor is offline   Reply With Quote
Old 09-08-2009, 06:52 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
i would pre drill the ipe, you will most certainly snap some heads off the stainless steel screws. and even when you pre drill you must be careful. Good luck.
Old 09-08-2009, 07:07 AM   #3
What bob said. Ipe is REALLY hard, and SS screws are generally brittle. Predrill. But consider on of the hidden fastener systems. No screws on top will make that Ipe look much better.
Old 09-08-2009, 09:49 AM   #4
dIYHell
Rewards Points: 150
The deck is going with a remodel that we did that has a modern design to it and I like the industrial loook the screws give. Also I believe the top down gives a much more stable attachment keeping the boards from warping.
What hidden fasterner system would you recommend if the deck is inaccessible from the bottom? Im assuming I will have to slot the boards for any that I use?
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 08:08 AM
Decking Screws - Color? sandyman720 Building & Construction 5 05-30-2008 05:46 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 08:51 PM
