Screws In Framing? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-18-2010, 09:46 AM   #1
Screws in framing?
Why is it not a good idea to use screws,like deckmate, in a framing project? Thank you for your time?
rsclark67 is offline   Reply With Quote
Old 04-18-2010, 09:54 AM   #2
Concrete & Masonry
Rewards Points: 548
Standard screws don't have the sheer strength of a framing nail, UNLESS they are made specifically for framing. Framing screws are hard to find & far more expensive than nails though.
jomama45 is offline   Reply With Quote
Old 04-18-2010, 12:15 PM   #3
kwikfishron's Avatar
Rewards Points: 418
Not to mention nails are fast, screws are slow. Although I use screws here and there in remolding. Sometimes you just canít get a nail in there.
kwikfishron is offline   Reply With Quote
Old 04-18-2010, 01:37 PM   #4
All trades carpenter
Most people thinks screws are stronger. As mentioned the right type of screw will do but lots of people use the wrong type of screws. Most of them do not have the shear strength that a nail does. Drive say a 2 1/2" drywall screw down till there is only a 1/2" still exposed and then do the same with a 8d sinker. Take your hammer using a sideways swing hit the screw and nail head. Usually the screw head will snap and the nail will bend.
CrpntrFrk is offline   Reply With Quote
Old 04-18-2010, 02:38 PM   #5
Civil Engineer
Rewards Points: 4,700
Oh the misunderstood screw. The shear strength of a steel screw or nail is controlled by the ultimate tensile strength of the steel itself, and the diameter of the screw or nail. A screw with the same root diameter as a nail, made of the same type of steel, is just as strong in shear, and a great deal more resistant to pullout. The key is to measure the ROOT diameter of the screw, not the THREAD diameter. Since the root diameter is always smaller than the thread diameter, comparing a screw with a thread diameter of 1/8 inch to a nail with a 1/8 inch diameter is incorrect, and can lead to the misunderstanding that screws are not as strong in shear.
Nails are certainly faster to install, however in critical applications like attaching roof sheathing to rafters in high wind (read hurricane or tornado zones), screws beat equivalent sized nails hands down for performance. For framing of non-critical members, nails are simpler and faster, but there is a place for screws. Check out the Simpson catalog, there are numerous types of framing rated screws described in there, and a few of their hangers require screws.
Old 04-18-2010, 02:43 PM   #6
So once again...... the point is to get the right type of screw......
Old 04-18-2010, 02:54 PM   #7
remodeling pro
As posted, screws (especially drywall) are very brittle and do not have much shear strength. If you want to see this, drive a drywall or deck screw and a 16d nail about half way into a piece of wood and try to bend them over with a hammer. The screw will immediately snap off, while the nail will bend over until it lays flat on the wood.
troubleseeker is offline   Reply With Quote
Old 04-18-2010, 04:14 PM   #8
Thank you all! Would you consider deckmate screws as a framing screw?
Old 10-20-2010, 11:34 AM   #9
Rewards Points: 20
Bump, because thread is not that old
Although an interesting test here is another one:
Drive a drywall or deck screw (drywall are more brittle, though) and a 16d nail about half way into a floor joist. now use a pair of pliers to grab onto the bottom and see which one can hold your weight.
Diameter of thread root and nail aside, nails are more pliable and less prone to break when under shear forces, but they have far worse tensile, since they'll simply pull out, though a ring shank will hold well. Which is better for framing a structural wall I don't know--I'm inclined to say nails, since that's what code typically prefers, if not literally mandates.
Framing a non structural wall like for a basement finishing it seems to me screws have a benefit because they're more likely to avoid pulling out as the wood settles/dries in the wall. I'm doing mine now and have used screws--specifically deck mate--in most walls. I do prefer working with screws out of habit and replacing studs if necessary is obviously a thousand times easier because it can just be unscrewed.
Certainly none of the few hundred screws put in have snapped as the wood has dried out further.
Skoorb is offline   Reply With Quote
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 01:56 PM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 08:56 AM
How many deck screws? Jeremy Hillary Boob, PhD Building & Construction 10 09-20-2009 09:09 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
