Screws - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 02:47 PM   #1
Screws
What type of screws should I use on my cedar deck
pgowdy is offline   Reply With Quote
Old 11-17-2011, 02:55 PM   #2
Rewards Points: 5,336
Deck screws. Color of your choice.
You can also use hidden fasteners so you don't see anything visable.
Ron
B. Franklin 1759
Old 11-17-2011, 04:19 PM   #3
Civil Engineer
Rewards Points: 4,790
I am assuming you want to use the screws to attach the deck boards, not for the framing. Stainless steel screws work well, I used stainless trim screws with a colored head on my ipe deck, they worked quite well. I imagine they would be fine on cedar as well. The were #10 square head screws, about 2 inches long. Because it was ipe, I had to predrill all the holes, you may wish to do the same with cedar as it is somewhat brittle and prone to splitting.
Daniel Holzman is online now   Reply With Quote
Old 11-17-2011, 04:31 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
stainless steel works great but are expensive in comparison to regular deck screws.
regular deck screws are pretty much the same screw as an interior screw except they have an epoxy coating which keeps them from corroding. there are different colors available, brown works best for cedar and believe it or not looks better in pressure treated as well..... reason being once the wood starts to age it turns gray. green deck screws stand out more in a faded pt deck in comparison to the brown ones
woodworkbykirk is offline   Reply With Quote
are deck screws enough to stop a kick in? Tonglebeak Carpentry 18 12-10-2011 08:19 PM
Drywall nail types kevsprojects Drywall & Plaster 23 07-31-2011 07:34 PM
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 08:56 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
