Screwing Steel Studs The Hard Way - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-28-2013, 07:35 PM   #16
Roofmaster
Rewards Points: 2,210
You are doing all this to gain less than 1 square foot of space in a closet? There must be a really good reason?
Old 04-28-2013, 07:39 PM   #17
This is for an apartment that I own in a co-op and there are rules and inspections by the manager who doesn't know the building code. I was afraid of her seeing that I added a wooden extension to the existing plaster and mesh wall. Steel is the rule for commercial buildings for a reason, and it's good for residential apartments for the same reason. It resists fire better than wood. It's a "fireproof" building built in the 1960s.
Dorado is offline   Reply With Quote
Old 04-28-2013, 07:48 PM   #18
All of the closets in the apartment, including the hall closet, are slightly under 22" deep. The extra 8" of depth in this bedroom closet will increase the floor space by about 500 sq. in. and make this the only decent sized closet in the apartment. I wish there was room to extend the others. The reason I started this wall was so I'd have a hollow wall for phone and coax jacks, then I figured I should build one on the other side of the closet to extend the closet.
Old 04-28-2013, 09:39 PM   #19
Rewards Points: 636
we almost always use a 1/2 inch modified truss head screw.
as far as removing screws it does happen mostly at deflection points where slotted track can not be used.
as far as welding studs never seen it done to track but years ago we would have to weld stiffeners in place or use a special screw clip "which was a pain on heavy gauge studs" to studs to create a shear wall when adding a mezzanine
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
How to add blocking w/ steel or metal studs bergerdude Building & Construction 12 04-30-2013 09:59 AM
Steel studs for basement, size? D270 Building & Construction 8 01-28-2013 09:31 AM
Building Basement with Steel Studs...which Electrical Boxes can I use? tbeem1 Electrical 18 06-13-2012 11:28 AM
Steel studs over XPS in basement fnsane Insulation 1 02-23-2012 06:45 PM
Basement and Steel or metal stud question maxim1 Building & Construction 14 12-01-2011 09:52 PM
