Screwing Hardiebacker On Top Of Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 08:48 PM   #1
Rewards Points: 1,062
Question
screwing hardiebacker on top of subfloor
if i am screwing hardiebacker on top of 3/4" subfloor, should i still be aiming for joists underneath or can i screw it into subfloor only ?
i was thinking the former, which is certainly firmer, because all the screws available at HD were 1-1/4 and 1-5/8", which would both protrude on the other side if using 1/4" hardiebacker and screwing into subfloor only.
Old 04-11-2011, 09:44 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Subfloor only. But First: What is the subfloor made of?
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
amakarevic (04-11-2011)
Old 04-11-2011, 10:21 PM   #3
Question
it is 23/32" OSB pannel. but does it matter if i do go into the joists only? because any screw they have available at HB will protrude on the other side and i have a personal screw/nail policy of never protruding.
Old 04-11-2011, 10:26 PM   #4
Rewards Points: 5,336
Then screw it into a joist so your personal policy isn't at risk.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Old 04-12-2011, 05:00 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The industry recommendation is to NOT screw into the floor joists in this case. However, we wouldn't want to violate any personal policy you may have, what does the industry know about the subject anyway. Screw into the joists if you must.
XXX
Old 04-12-2011, 05:05 PM   #6
DIY staff
Rewards Points: 7,174
I believe the screw pattern for Hardibacker is about every 8"---I suggest you add extra Joists to avoid the protrusion problem.
Old 04-12-2011, 05:22 PM   #7
Question
but why ? what does extra firmness hurt ?
Old 04-12-2011, 05:25 PM   #8
Remodeler
Rewards Points: 324
Most any type of underlayment requires closer fastener spacing than joist spacing. I usually go with a 6-8 inch grid spacing over the entire sheet. Too close is much better than too far apart! If you are installing backer to tile over you should also be laying the backer in a bed of thinset.
Tile is expensive, lots of work to install and even harder to tear out, you want to get it right. If you absolutely don't want it to protrude then use a thicker product or find shorter screws.
iamrfixit is offline   Reply With Quote
Old 04-12-2011, 05:29 PM   #9
Question
this is for a boiler/water heater alcove. both gas. i really don't have to make it look pretty. i did not put a bed of thinset. is there any flooring alternative to tile to go under these appliances that will provide sufficient heat insulation ? this is on the 1st floor, there is a basement underneath.
Old 04-12-2011, 07:23 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No none!
Oh-oh!
Not to worry - it ain't gonna!
How about using 1/2" Hardi, the cost is the same is it not? Whoops, never-mind it is already installed, huh!
XXX
amakarevic (04-12-2011)
Old 04-12-2011, 11:40 PM   #11
good to know for the powder room cause that's next and that needs to look purty, unlike the alcove. if the tiles crack there, i don't really care. it was a good learning ground.
Screwing down subfloor & crowned joist? roar24 Flooring 1 03-20-2011 04:27 PM
Hardiebacker/ Floor Tiling question.......remaking the "BOMB SHELTER!" Dyoung Building & Construction 5 03-20-2010 09:09 AM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Spacing for screwing subfloor. Clutchcargo Building & Construction 3 10-05-2008 09:04 PM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
