Screwing In Drywall By Hand? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-04-2006, 10:39 PM   #16
yummy mummy's Avatar
Rewards Points: 1,016
Atlantic
I want to THANK YOU, for your amazing step by step instruction, at the begining of my postings for framing.
I have completed one 15 foot wall of framing today.
Thank you, thank you.
You are fabulous.
I do look forward to continued help.
yummy mummy is offline   Reply With Quote
Old 11-04-2006, 11:44 PM   #17
renovations
Yummy, you can buy a special clutched bit for drywall screws that fits in a regular drill, it sets the screw to a certain depth. I don't find them any easier to use than the drywall guns, however, they're cheap so you might wanna give em a try.
Bonus is offline   Reply With Quote
Old 11-05-2006, 09:18 AM   #18
bonus
thanks bonus, I will be purchasing that bit.
I just hope that I am able to use it successfully.
Old 11-05-2006, 10:19 AM   #19
Yummy, Try installing a drywall screw by hand into a scrap of 2x4 wood. This will certainly have you looking at a drill driver or hammer quickly.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-05-2006, 10:37 AM   #20
747
registered
747's Avatar
Rewards Points: 534
That is the ticket. Turns any drill in to a drywall drill. Its also inexpensive. Would recomend that or just to nail. If nailing make sure you leave a dimpel.(spelling i'm so bad at spelling )
http://www.hobbytool.com/index.asp?P...ROD&ProdID=308
747 is offline   Reply With Quote
Old 11-05-2006, 01:25 PM   #21
Thanks 747.
That is the exact same one that I have seen and I will be purchasing it.
But I do have to try doing it by hand.
Your spelling is fine, I understand "dimple"
Old 11-08-2006, 11:09 PM   #22
Greetings--
I've seen an adaptor made for sheetrock screws that fits on a drill. I'd suggest using either a drill/adaptor or go spring for an inexpensive sheetrock gun (ie Harbor Freight tools). Screwing them by hand wont work well. Screwing them in with a regular drill will give poor results, driving them too deep through the paper.
Piney is offline   Reply With Quote
Old 11-08-2006, 11:20 PM   #23
piney
Thanks for the info.
I hope I can find the adaptor in Toronto, Canada.
Bathroom Drywall jeepwillies Drywall & Plaster 11 05-03-2011 12:04 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 05:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
