Screwing Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-05-2010, 06:43 AM   #1
Rewards Points: 31
screwing drywall
what's the best way to screw the 4x8 drywall in walls and in ceiling(soffit)? I'm installing it perpendicular to the studs. Should I put screws on every stud or every other stud? Should 4 screws (2 on both ends/edges and 2 in the middle, basically every 12 inches from end to end) be enough?
kupalino is offline   Reply With Quote
Old 01-05-2010, 07:25 AM   #2
Remodeling Contractor
use 1 5/8" screws. every 6" along the edges every 12" in field. Screws to every stud
Old 01-05-2010, 07:30 AM   #3
Too Short? Cut it Again!
Me too and screws are cheap if you buy them in bulk. You do not want to skimp or you will pay the price later.
Old 01-05-2010, 08:46 AM   #4
Chicago, IL
Michael Thomas's Avatar
Per US Gypsum's installation instructions, .50 inch ceiling panels should be nailed every 7" or screwed every 12" and fastened "to all joists or perimeter framing" at a span no greater than 16" if installed parallel or 24" if installed perpendicular to the joists. (You can install .50 inch panels parallel to the joists by using USG's "sag resistant " panels.)
http://www.usg.com/USG_Marketing_Con...tion_guide.pdf
Like some others here, I use approximately 6" spacing for screws at panel edges "just to be safe".
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Big problem with screwing a bracket to drywall bobman0330 General DIY Discussions 4 11-06-2007 01:35 PM
screwing in drywall by hand? yummy mummy Building & Construction 22 11-08-2006 11:20 PM
