Screwing Cementious Wallboard - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-12-2009, 09:45 PM   #1
Rewards Points: 135
Will be putting up some of this stuff as a tile backer around a tub. Any tips on: 1) cutting it 2) screwing it or otherwise attaching to wall- do I use regular black wallboard screws or go with galvanized deck screws? 3) will the little wallboard thing you can put at the end of a drill to properly set screws work with cementboard?
smata67 is offline   Reply With Quote
Old 07-12-2009, 10:06 PM   #2
Rewards Points: 5,336
They sell special cement board screws. Use those. A regular drill with a phillips tip will work fine.
Ron
Old 07-13-2009, 10:39 AM   #3
LeviDIY's Avatar
Rewards Points: 252
Disclaimer: I'm not a pro.
I just did a shower surround with CBU, and was my first time installing it - onto metal studs, but a couple things I learned:
- Cutting: my circular saw did well with a special carbide blade attached... DONT try to use a regular blade, will spark and probably ruin your saw. BUT, it creates a massive amount of dust, so do well away from the house outside with a mask and goggles. Also, I found that a utility knife w/ carbide blade worked better, just a little slower. I bought a carbide tipped 1 1/4" circle hole cutter bit for my 12 volt cordless drill, and that worked real well for getting the shower head and handle fixture holes cut.
- Mounting on the wall: like Ron said, they sell special screws for Hardibacker/Durock. In my mind, worth the extra couple bucks because I was worried about water/rust. Be sure to spread a separate coat of thinset over them.
- Mounting: I'm curious if the pros will agree, but I found that pre-drilling with a carbide tipped bit through the CBU and into the metal stud, then going back in with the Hardi screws on my screw gun made it much easier. I arrived at this method because some of the initial screws I just went in on the end of the CBU on the stud came real close to the edge of the CBU piece and caused it to crumble on the edges.
Just my 2 cents.
LeviDIY is offline   Reply With Quote
fixing wallboard holes deetu General DIY Discussions 6 01-14-2009 06:22 PM
Can Sagging Ceiling Wallboard Be Straightened? MrBill_DIY Building & Construction 4 07-23-2008 02:42 PM
wallboard type analogmusicman Building & Construction 3 02-20-2008 04:24 AM
Big problem with screwing a bracket to drywall bobman0330 General DIY Discussions 4 11-06-2007 02:35 PM
What type of wallboard? woodeagle Painting 2 01-12-2007 11:53 PM
