Old 09-30-2009, 01:27 AM   #1
Screwed up calculations, How bad is this?
Hi Guys,
I completely mixed up my calculations and I installed my 2x6 ledger board on the exterior wall(the load bearing wall) of my home using 5/8 4 inch lag screws almost 6 inches too low.
I put the lag screws every 16 inches on center essentially bolting to each 2x4 stud.
How bad is it if I remove the ledger board and the lag screws? Is the integrity of the studs/load bearing wall compromised? Should I just install another ledger board to meet my revised calculations above the one I just installed
diyintexas is offline   Reply With Quote
Old 09-30-2009, 10:30 AM   #2
The structure of the studs would not be compromised by removing the lag bolts.
If it's a small piece of wood you could just change the 2x6 to a larger size beam.
Ron
Screwed down Sub Floor, but still squeaking? rlc2052 Flooring 15 03-10-2009 02:20 AM
Screwed up stair stringer (picture in thread) iMisspell Building & Construction 9 11-13-2008 11:49 AM
Am I SCREWED? Stairs & building code. Armitage Building & Construction 24 06-26-2008 05:05 PM
2x100a sub on service main jambud Electrical 17 03-12-2008 10:31 AM
