Screw It Or Nail It? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-24-2007, 03:38 PM   #1
screw it or nail it?
Howdy!!
New to the forums. Glad I found y'all.
Looking at replacing my old POS wood siding with cement fiber board. I have talked to a number of people about this project. Some say to use a nail gun and nail the siding in with stainless steel nails or masonry nails. Others say to predrill the holes then screw the stainless screws into the CFB. What have y'all done, if you could have done it differently, would you? Last but not least, a rather off the wall question...is Hardi Plank the same thing as cement fiber board? Or is Hardi Plank just a name brand...like Kleenex and facial tissue?
thanks for the time.
scatterbrain
scatterbrain is offline   Reply With Quote
Old 06-24-2007, 04:01 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by scatterbrain View Post
....Some say to use a nail gun and nail the siding in with stainless steel nails or masonry nails. Others say to predrill the holes then screw the stainless screws into the CFB. What have y'all done, if you could have done it differently, would you?
Here is information from the James Hardie website - on the installation procedures for their fiber cement lap siding. Screws may be used, no need to pre-drill. It is FIBER cement siding, not solid cement siding :
FASTENER REQUIREMENTS
FACE NAILING
Corrosion Resistant Nails (galvanized or stainless steel)
6d (0.113" shank x 0.267" HD x 2" long)
Siding nail (0.089" shank x 0.221" HD x 2" long)
Siding nail (0.091" shank x 0.221" HD x 1-1/2" long)*
Corrosion Resistant Screws
Ribbed Wafer-head or equivalent (No. 8-18 x 0.323" HD x 1-5/8" long) Screws must penetrate 1/4" or 3 threads into metal framing.
Corrosion Resistant Fasteners
ET & F pin (0.100" shank x 0.25" HD x 1-1/2" long)
BLIND NAILING**
Siding nail (0.089" shank x 0.221" HD x 1-1/4" long)
11 ga. roofing nail (0.121" shank x 0.371" HD x 1-1/4" long)
Ribbed Wafer-head or equivalent (No. 8-18 x 0.323" HD x 1 5/8" long) Screws must penetrate 1/4" or 3 threads into metal framing.
ET & F Panelfast™ (0.100" shank x 0.313" HD x 1-1/2" long)
http://www.jameshardie.com/homeowner...stallation.php
Here is a video with more installation information:
http://www.hgtvpro.com/hpro/pac_ctnt...&videoid=66953
scatterbrain
Hardi Plank is a name brand of fiber cement board. There are other manufacturers out there producing fiber cement board lap siding like Certainteed Weather Board:
http://www.certainteed.com/CertainTe...rCementSiding/
- Build Well -
Old 06-24-2007, 06:34 PM   #3
carpentry
WNYcarpenter's Avatar
Fiber cement siding works, cuts, handles and installs completely different that other siding materials. The product itself is great, but takes some getting used to.
I have two tips...use the nippers! and when using the nippers, mark and cut your piece upside down!
People will tell you that you can use convential tools like a circular saw or miter saw to make your cuts, but the dust is as bad as asbestos and even using a diamond blade,you're putting unnecessary stress on a saw not intended to cut fiber cement.
WNYcarpenter is offline   Reply With Quote
Old 06-24-2007, 10:38 PM   #4
Yep he is right. I used the stuff a whopping one time on a really small project and I loved the diamond blade. However I was to cheap to buy the nippers ( I never rent things I love to buy them ). I hear that the nippers are the best.
warnerww is offline   Reply With Quote
Old 06-25-2007, 05:19 AM   #5
For more information about Fiber Cement board lap siding, installation, tools, cutting, and the silica dust and glass fiber dangers - do a search on this site.
There has been other discussions about techinques, etc....
Example:
Siding Nails
- Build Well -
Old 06-25-2007, 06:07 AM   #6
thanks to everyone for your comments and responses. Y'all helped tremendously.
buying a nail gun with compressor Dave777 Tools 9 11-27-2011 11:37 PM
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 01:54 AM
Using nail gun on deck fence? darsunt Carpentry 1 05-01-2007 08:11 AM
nail pops nat Carpentry 3 11-11-2006 12:48 PM
Nail Gun and Compressor - Help! MelindaA Carpentry 7 08-15-2006 08:17 AM
