Screw Hardware Issue - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2013, 11:42 PM   #1
braves22's Avatar
Ok first let me start off by saying I wasn't sure where to put this question.
Anyways here goes...I am installing a ceiling fan and I got down near the end of the project BUT I am installing the blades and 1 screw hole on a single blade (holds 2 screws) just won't budge AT ALL...
So I guess what I am curious about is if anyone has any tricks they know of so that I can either go buy another screw or get it through...the man thing I am looking at is that it seems as though there are no threads inside the hole at all...someone help!!
braves22 is offline   Reply With Quote
Old 01-24-2013, 06:01 AM   #2
Rewards Points: 1,296
Sounds like the hole was not tapped properly. You may need to find a tap to thread the hole or return it for a different one.
I wonder if the whole monday/friday quality issue is the same in China as it used to be here in the states
danpik is offline   Reply With Quote
Old 01-24-2013, 08:21 AM   #3
braves22's Avatar
Well this is fan 2 of 2 with some sort of screw quality control issue...
The first one was on the canopy screw and I was able to use a hammer to knock it into the hole and screw through....
This one the screws are on top of the mounting piece so I can't hammer it in and it'd be VERY difficult at this point to return it as I have the entire unit now mounted...
Can I find screw taps at any hardware store? Should I be looking in a particular size (IE size of the screw?) and frankly I'm not sure what size they are as it isn't listed....
I was hoping I wouldn't have to take the whole thing down if possible
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 08:19 AM
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 01:56 PM
Allen screw and copper pipe? dolvio Plumbing 1 02-09-2009 06:38 PM
Would you staple, nail or screw? Speedball Flooring 7 11-28-2008 11:21 AM
