Screen Room Framing Help - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 05:57 AM   #31
kwikfishron's Avatar
Rewards Points: 1,002
Originally Posted by ScottFla40 View Post
Care to elaborate??
Not really... other than between calling family “the owners” and post 22 and 23 speaks volumes too me. Maybe (hopefully) my assumptions are wrong.
kwikfishron is online now   Reply With Quote
Old 08-28-2012, 05:58 AM   #32
Rewards Points: 150
Ill add a couple things that might help you out
1. The top needed to be flat and level, not turned up on the angle of the rafter.
2. Should use 4x4's for the uprights, a single 2x4 PT will want to warp and twist.
3. Your blocking between rafters looks great, maybe get some thick vinyl or rubber mat cut to the roof to finish it off, foam wont look so good.
4. Your side wall layout isnt so hot, cant you start in the corner with a 4x4 and work from that?
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
The Following User Says Thank You to Hammer450R For This Useful Post:
ScottFla40 (08-28-2012)
Old 08-28-2012, 06:48 AM   #33
ScottFla40's Avatar
Well if you don't care to elaborate, With all do respect, don't reply. If you have something to say, say it.. We are all grown men here. Don't be sarcastic and say certain number posts speak volumes. I am not going to count posts and reply to each one.
ScottFla40 is offline   Reply With Quote
Old 08-28-2012, 06:51 AM   #34
AHH, SPANS!!!
Rewards Points: 1,166
maybe consider taking out the vertical 2x4 against the house wall and putting a 2x4 against the wall of the house that matches the 2x4 rafters for the porch and then put the vertical 2x back in cut up tight to the new rafter and then fill in at the top like all of the rest of the porch and then screen over to the house... looks like there will still be a weird air space between the house overhang and the porch roof where bugs could get in and water?? not sure how bad it is from looking at the last couple pics but something could be worked out there...
hand drive is offline   Reply With Quote
Old 08-28-2012, 07:57 PM   #35
ScottFla40's Avatar
A few more angles on the bugaboo corner... I have officially hit the wall....
Screen room framing help-image-977686195.jpg   Screen room framing help-image-247498399.jpg   Screen room framing help-image-2152657704.jpg
Old 08-28-2012, 08:57 PM   #36
AHH, SPANS!!!
that is a tricky one. I suppose you have been glancing up at that spot the entire job wondering what is going to happen there?
Old 08-30-2012, 06:26 PM   #37
DIY staff
Rewards Points: 7,174
Long wedge shaped screen?
Old 08-30-2012, 07:58 PM   #38
AHH, SPANS!!!
just looking through this thread again, looks like a rafter added against the house that emulates the last porch rafter and then blocking added that matches the porch and the porch fascia extended over to the house. after it is framed slide a piece of the clear roofing up until it hits the house overhang at the top and screw wherever you can get screws into it, maybe consider some glue applied from underneath as well( lift roofing, dab glue,set roofing back down into the glue...) with that roofing up there it will be a matter of just continuing the screen over to the house and being done with it. I've had many a roof lines run into soffits and overhangs, happens all the time.
screen room forti5 Building & Construction 1 10-01-2011 01:53 PM
Vapor Barrier on elevated 4 season room Indyc0lt Insulation 3 09-15-2011 01:41 PM
Brainstorming ideas to Dress Up the front room of my new house!! the_d_mann1 Interior Decorating 0 05-01-2011 04:47 PM
Painting room finally Imkindofbigdeal Painting 10 03-16-2011 03:22 PM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
