Screen Room Framing Help - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 10:55 AM   #16
ScottFla40's Avatar
Well I wanted to post an update on progress... Thanks to everyone who chimed in with their advice. Here are some pics...
Screen room framing help-image-3747826725.jpg   Screen room framing help-image-2098197917.jpg   Screen room framing help-image-3385943918.jpg   Screen room framing help-image-2590267537.jpg   Screen room framing help-image-1855892795.jpg
ScottFla40 is offline   Reply With Quote
The Following User Says Thank You to ScottFla40 For This Useful Post:
drtbk4ever (08-24-2012)
Old 08-24-2012, 11:41 AM   #17
AHH, SPANS!!!
Rewards Points: 1,166
Great job! should stay up for the long run. a couple suggestions that will help... a corrugated roof seal is available that could slide into the underside of the roofing and over top the blocks between the rafters and that would seal the space at the very top look in the metal roofing section at the lumber store
Also, for installing screen I've found a way that works great. When installing the screen pick the straightest side and start on that side ( I usually want to staple across the top first). For example.. I put about 3 or 4 staples in one corner (top left)and then go to the other corner (top right)and pull the screen tight and staple there at that corner and then go back to the middle of that span and pull the screen up a bit if needed to make it straight and staple there at the middle. Then just fill in from the middle outward toward both edges. After the first top straight section is completely stapled all the way across, you use that stapled section to square the rest of the screen off of. Next, grab both bottom edges of the screen and pull tightly downward and pick a bottom corner to staple to. As yo pull down you will be able to see the screen square itself off of the first stapled edge. if it is not square it will have wrinkles in it, so once you determine were it sits square put a few staples in the corner and then staple that side back up to the top making sure the screen is straight. Now go back to the other bottom screen corner and pull straight down and outward, this will tighten that last corner from 2 directions, staple it -and then as you staple back up the other side pull outward on the screen at each staple point. this tightens the screen all the way up and stretches it tightly side to side. Lastly, go back to the bottom and pull downward at each place you staple, this makes the screen tight top to bottom.
put staples in perpendicular to the way that you pull on the screen for maximum grab, and a hammer stapler works great just don't miss and punch a hole in the new screen
hand drive is offline   Reply With Quote
Old 08-24-2012, 03:17 PM   #18
ScottFla40's Avatar
Thanks for the compliment & advice... The gap between the existing corrugated roof and board & rafters is barely a 1/8", when I walk with the owners I will speak with them regarding it however they seemed ok with it when I previously explained it to them. We'll see....
hand drive (08-24-2012)
Old 08-24-2012, 03:24 PM   #19
AHH, SPANS!!!
the sealer is formed to fit into the wavy roofing corrugated profile but depending on how good the bugs noses are down there in Florida will determine if they find that space to come into the porch, lets hope not
oh yeah, on stapling they need to be every 2", forgot to mention earlier in my post. Good luck!
Old 08-26-2012, 06:19 PM   #20
ScottFla40's Avatar
So since the weather has been uncooperative I have had time to try and figure out the last piece to the puzzle. I attached some pics that show where the patio roof ends. Looking for ideas on how to finish the enclosure. Thoughts, opinions are welcome..... Thanks....
Screen room framing help-image-2588603295.jpg   Screen room framing help-image-3382676534.jpg
Old 08-27-2012, 05:54 PM   #21
ScottFla40's Avatar
All my engineers bailed on me!!!!!...
Old 08-27-2012, 06:13 PM   #22
kwikfishron's Avatar
Rewards Points: 378
Your getting paid for this?
kwikfishron is online now   Reply With Quote
Old 08-27-2012, 07:21 PM   #23
ScottFla40's Avatar
That bad huh???...
Old 08-27-2012, 08:37 PM   #24
DIY staff
Rewards Points: 7,174
To long of a day to think---I'll read this later and see if I can suggest something---
I thought this was for relatives.--If it's for paying strangers---not so good---Always practice on friends and relatives.--Mike----
Old 08-27-2012, 10:17 PM   #25
ooooo
Tham is offline   Reply With Quote
Old 08-27-2012, 10:33 PM   #26
Rewards Points: 378
That bad huh???...
Old 08-28-2012, 05:10 AM   #27
ScottFla40's Avatar
It is for my father in law and his g/f. Be glad to hear any suggestions you have Mike. I am always looking to improve..
Old 08-28-2012, 05:13 AM   #28
ScottFla40's Avatar
Any suggestions Ron??..
Old 08-28-2012, 05:14 AM   #29
ScottFla40's Avatar
Care to elaborate??
Old 08-28-2012, 05:19 AM   #30
DIY staff
We all need willing Guinea Pigs.
Unfortunately--I'm late leaving for work---so someone else will need to help--Looks rather straight forward---and your framing is improving---
I was lucky--as a kid my dad had a carpenter frame up an addition on the house and Dick Russel must have liked kids----I learned a lot from him and remember his wise words like it was just yesterday---Mike----
screen room forti5 Building & Construction 1 10-01-2011 01:53 PM
Vapor Barrier on elevated 4 season room Indyc0lt Insulation 3 09-15-2011 01:41 PM
Brainstorming ideas to Dress Up the front room of my new house!! the_d_mann1 Interior Decorating 0 05-01-2011 04:47 PM
Painting room finally Imkindofbigdeal Painting 10 03-16-2011 03:22 PM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
