Scraping Hardened Concrete From A Mixer - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-20-2007, 11:16 AM   #1
Rewards Points: 1,062
Question
Scraping hardened concrete from a mixer
is there an elegant (chemical) solution or do i have to keep digging and chiseling ?
Old 06-20-2007, 11:44 AM   #2
Use a fast rotary tool with proper disc attachment to remove it.
KUIPORNG is offline   Reply With Quote
Old 06-20-2007, 12:04 PM   #3
Question
RotoZip
Will RotoZip do ?
Old 06-20-2007, 12:21 PM   #4
also
can you tell me what the proper attachment is ?
thanks,
- a
Old 06-20-2007, 12:35 PM   #5
Rotozip will do... the best attachment I find working for me so far are those thick(1/4") sanding disk... but in theory... anything will work... just of different speed and some attachement allow you to reach some area whereas other couldn't.... try to use what you have on hand first before spending $$ on new ones...
Old 06-20-2007, 12:55 PM   #6
A regular concrete mixer? hit the side with Sledge hammer. Or dynomite will work also
RYANINMICHIGAN is offline   Reply With Quote
Old 06-20-2007, 02:33 PM   #7
I think the poster is talking about those left over mud which cannot be knock off easily though....
Old 06-20-2007, 03:10 PM   #8
who cares then. Ever seen a concrete mixer clean as the day it was bought?
Old 06-27-2007, 12:10 AM   #9
Electrical Contractor
post a picture of the tool you are talking about? I can't see any rotozip attachment that would cut through concrete in a timely manner I agree with the sledgeomatic routine. For godsakes it's a concrete mixer not a dinner plate. Mine is pretty clean although I wash it after using it.
terrynistler is offline   Reply With Quote
Old 06-27-2007, 05:07 AM   #10
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Hers's an option:
http://www.safe-react.com/conrem.htm
- Build Well -
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 08:58 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
