SCIP Panels - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 09:10 AM   #1
SCIP Panels
i will like to use Steel Concrete Insulated panel SCIP
on a remodeling exterior walls and concrete will touch wood
what can i use to coate wood for it not to rot
propvision is offline   Reply With Quote
Old 04-04-2013, 09:17 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the Forum!
you got me on this one, I know of Structural Insulated Panels (SIP's) which are wood structural panel sheathing with foam insulation in between that are commonly used as exterior walls and roofs. And I know of Insulated Concrete Foams which typically are styrofoam panels connected with plastic webbing that are filled with concrete to create either foundations or exterior walls, but I've never heard of steel concrete insulated panels.
are you saying these are used as exterior walls (do they happen to match with my description of SIP's above?)
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-04-2013, 09:27 AM   #3
Rewards Points: 12,812
http://www.highconcrete.com/educatio...-metal-panels/
GBrackins (04-04-2013)
Old 04-04-2013, 09:29 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 864
You can use PT lumber or you can use a capillary brake.
I wouldn't trust a coating alone and would prefer to see a 100% capillary brake or other isolation.
Old 04-04-2013, 09:32 AM   #5
GBrackins's Avatar
Originally Posted by joecaption View Post
one learns something new every day, thanks Joe!
Gary
Neutral path between two main panels EMiller Electrical 13 03-17-2014 08:48 PM
3 phase panels and sub panels michael825 Electrical 32 08-31-2011 09:43 AM
How to flush water heater that has solar panels Homerepairguy Plumbing 2 11-11-2010 09:26 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
