Scafolding With Planks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-28-2009, 05:10 PM   #1
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
scafolding with planks
I was driving by a stucco crew doing some work, and they had what they called jacked posts made out of 2x4's that leaned up against the house and then they laid there walking planks on top of that, they had 6' and 12' ones. Has anyone seen something like this before?
ryanh is offline   Reply With Quote
Old 10-29-2009, 06:17 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Yep. They're called pole jacks or pump jacks. The aluminum planks are called stages or some guys call them picks. They are available in different lengths and widths with different options, railing, etc.
Old 10-29-2009, 11:39 AM   #3
Rewards Points: 3,130
Around here they're called pump jacks. First saw them 25 years ago when my house was built.
Old 10-29-2009, 11:46 AM   #4
ArmchairDIY's Avatar
......and they are not just leaned up against the house they have brackets that hold them in place.
You step on a peddle to "pump" your self up to the desired height.
ArmchairDIY is offline   Reply With Quote
Old 10-29-2009, 11:58 AM   #5
Here you go. Pick up the entire set. Free Shipping!!!
http://www.amazon.com/gp/product/B00...KPH2N9GCN7W1SS
jerryh3 is offline   Reply With Quote
Nailing down engineered wood planks ? Flt_Simulation Flooring 2 05-14-2009 04:36 PM
Applying 3/8 plywood on top of 3/4 wood planks?? the punisher Flooring 2 05-12-2009 10:01 AM
Karndean vinyl planks CMACK Flooring 2 02-28-2009 07:12 PM
Preparing 5/16" cedar planks Clutchcargo Carpentry 3 07-07-2008 08:57 AM
