-   -   scaffold on top of roof (http://www.diychatroom.com/f19/scaffold-top-roof-154475/)
brian89gp 08-22-2012 10:11 AM
I am needing to erect a scaffold on top of a first story addition in order to get to the second story, and then a bridge over to the chimney. How do I go about attaching the scaffolding to the roof and securing the end of the bridge to the roof by the chimney? Shingles are 15 years old but was hoping to not have to replace them for a few more years.
The first story roof has a pretty gentle slope and the scaffolding would need to be a minimum of 20' tall. The second story as a 12:12 slope and the chimney is roughly 8' from the roof edge
hand drive 08-22-2012 10:25 AM
pics would help a bunch, otherwise it will be hard to make recommendations.
kwikfishron 08-22-2012 10:32 AM
199 Attachment(s)
What type of scaffolding? What exactly are you doing? How much weight will be up there?
As mentioned, post some pictures. http://www.diychatroom.com/f19/how-a...to-post-12559/
brian89gp 08-22-2012 10:50 AM
3 Attachment(s)
Pictures are attached.
Standard ladder frame scaffolding of some type. I have yet to buy it so options are open.
I am needing to get to the chimney to add some more brick to the top to make it taller. Total weight would be myself, mortar, and the brick.
kwikfishron 08-22-2012 11:11 AM
199 Attachment(s)
I don’t like your bridge idea. Roof jacks are all you need to get around on the roof.
Staging could be set up on that lower roof on top of a couple of long 2x12’s to distribute the weight but I’m not sure I see any advantage to that.
Essentially everything has to go up a ladder anyway. I’d just have an extension ladder with standoffs to get you on top of the roof and then roof jacks from there.
With a worthy helper running up and down the ladder to keep you up top things could go real easy.
Don’t forget the harness.
brian89gp 08-22-2012 11:23 AM
Would I put a toe board on the 2nd story roof, lay a ladder flat against the roof up to the chimney, and roof jacks around the chimney?
And something I have always wondered. What do you anchor your harness to before you climb up the roof some to install an anchor? Loop the rope around the chimeny?
kwikfishron 08-22-2012 11:37 AM
199 Attachment(s)
The roof jacks are what you use to secure the toe boards. After the ladder (with standoff) is set up you would have your roof jacks with tow board there to stand on to off the ladder, then more jacks and boards as necessary to access your work.
The safety harness needs to be anchored to a framing member, follow the manufactures instructions for specific details.
md2lgyk 08-23-2012 06:29 AM
Just out of curiosity, why do you feel the chimney needs to be taller??
It shouldn't take more than a day to add however many bricks you want to add. If it were me, I'd forget about ladders and scaffolding and rent a boom lift.
brian89gp 08-23-2012 07:03 AM
Fire code, 2' taller then any roof surface within 10'. I am putting in a wood burning fireplace and liner and the chimney is currently level or just below the ridge.
Boom lift, now there is an idea. I have a vent flange to put in up there too and roofers want $300 just due to the roof slope, the rental could probably pay for itself. A 61' boom lift at the local rental place is $280 per day.
md2lgyk 08-23-2012 09:39 AM
Just be aware, there's usually a hefty delivery charge for equipment like that. I rented one for a couple of days while building my log house. In my case, it was around $250, but they had to bring it over 20 miles. Oddly, the charge for the all-terrain forklift I rented was less.
brian89gp 08-23-2012 03:30 PM
I went and measured and the 61' boom isn't quite large enough. At the correct height the reach isn't far enough and vice versa.
Back to the roof jacks. My roof has the original wood plank sheeting (varying sizes) with slate, then asphault shingles nailed through the slate on top. Should I try and find a roof joist and nail the roof jacks to them with some 20d nails? I wouldn't think the normal roofing nails would be safe enough with the thickness of the roofing material I have to go through.
Any tips on finding a roof joist from on the roof?
kwikfishron 08-23-2012 03:53 PM
199 Attachment(s)
Are you sure about that??? That's a big machine. If you haven't yet, go to the manufactures website and look at the range of motion spec sheet.
md2lgyk 08-24-2012 07:16 AM
Yeah, something doesn't add up. I rented a 40-ft machine, and that was plenty. And I also have a 12/12 roof. Does the one you looked into have a straight boom, or is it articulated?
brian89gp 08-24-2012 07:44 AM
1 Attachment(s)
Pretty sure, it would be awful close if it did work. My back is to a garage and a concrete wall in those pictures so there is very little room.
Bil-jax 5533a.
The gutter is 25' off the ground, top of the chimney is 40'. Chimney is 15' from the edges of the house. Since my driveway is not wide enough (house on one side, stone wall on the other) for the 12'x12' footprint I would have to do from behind the house on a diagnol from the corner. Horizontal reach to centerline is just over 30' from that point.
The range of motion chart has it right at 35/40' lift @ 30' reach, so really close to the max. I will draw it out to scale this weekend and double check. Last thing I want to do is rent it and have it be a couple feet short or something.
kwikfishron 08-24-2012 05:01 PM
199 Attachment(s)
Even if it was just a couple of feet short it still gets you and your stuff up there.
Step off of that onto a toe board and you’re still way ahead. :thumbsup:
