Saw Blades - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2011, 12:39 PM   #1
Saw Blades
Will saw blades marked "cordless circular saw" work on a corded saw? I have a 6 1/2" Skill saw, corded, and some new saw blades marked for cordless saws. Can I use them or should I take them back and exchange. Thanks for your help.
jr0835 is offline   Reply With Quote
Old 06-29-2011, 01:47 PM   #2
Rewards Points: 5,336
I have never seen blades marked that way.
What are the RPM's of the corded vs. the cordless unit. Compare them to the limit on the blade. If they're within specs, I see no reason not to use them.
Ron
B. Franklin 1759
Old 06-29-2011, 05:07 PM   #3
Saw Blades
Your answer was right on ! My 6 1/2" corded saw runs at 5,500 RPM. Most corded saws run at 5,000, with some as high as 6,100 RPM. Cordless saws run 1,000 to 3,500 RPM. Stamp on the blade states that it is good to 7,000 RPM. The blades are DeWalt and stamped "Fits 6 1/2" cordless saws". Thank you for your answer. I can use them. The sales receipt states "Cordless saw blade".
Old 06-29-2011, 05:16 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
H-m-m-m-m! I've never heard of that either. Next thing you known they will be labelling the saw blades with "left side" and "right side" in addition to the direction arrow.
XXX
Old 06-29-2011, 05:48 PM   #5
The sales receipt has no bearing on the blade use. Stamped on the blade is a different story.
Ron
B. Franklin 1759
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Need Help Replacing Spiral Blades on Snow Thrower cynergyou General DIY Discussions 3 01-22-2011 08:53 AM
I keep bending blades in recip saw acerunner Tools 10 08-22-2010 11:35 AM
Sears 536.884351 auger blades are discontinued, no replacement MichaelLit General DIY Discussions 2 07-08-2009 06:43 AM
Miter Saw Blades \ Crown Moulding Jigs Discussion WorkOnIt Carpentry 3 06-17-2007 04:50 AM
