Sandstone Foundation Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 10:20 PM   #1
I am renovating an old Victorian home. Homes foundation is large Sandstone block. Block is beautiful and I am wanting to keep it. Most of the walls in the basement are Bowing inward. Keep getting mixed responses from contractors I have had out. I have been doing restorations for years now. I can tuckpoint, seal, insulate and run the irrigation around the home. Going to be excavating around the home and want to level the stone up. I have lifted houses before, and I know the procedure. I know I have to use a jacking system to level the walls straight, but the jacks to use I am having trouble finding. If anyone could point me in the right direction I would be greatly appreciated. I am definitely not a Rookie when it comes to this work, but I am stumped on where to find the right equipment for this job.
Thanks for you help!!
cwrose79 is offline   Reply With Quote
Old 03-19-2011, 10:51 PM   #2
liscenced electrician
Rewards Points: 538
i've always just used automotive bottle jacks. They can be had cheap enough that you can buy a whole bunch of them and jack at all the points you need to
jimmy21 is offline   Reply With Quote
Crawlspace foundation repair bmrsnr Building & Construction 12 01-20-2011 09:21 AM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 12:27 PM
Jack & shim foundation repair steps - feedback appreciated! vacatari Building & Construction 14 10-17-2010 10:32 PM
crumbling field stone sandstone foundation...can we resurface the visible outside portion? btolt162 Building & Construction 2 07-06-2010 12:04 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
