Old 10-14-2009, 03:46 PM   #1
Maladroit
Question Sand(topping) Drilling Tips Requested
I need to secure a flange to some newly poured sand/topping Quickrete we poured in our basement bathroom. This new slab is just 1 3/4" thick. I'll be securing bolts (and drilling) into the foundation concrete below the sand/topping slab. I have a brand new 19V cordless hammer drill that should do the job.
I'm concerned that if I hammer drill into the sand/topping it will just fall apart before I even get to the foundation concrete.
Are my fears valid? Any tips on drilling through this stuff? Also, the slab was poured five days ago. Am I good to go, or should I let it cure longer?
Obviously, I'm nervous about this. Any tips would be appreciated.
Drawquarter is offline   Reply With Quote
Old 10-14-2009, 10:19 PM   #2
i'd let it cure s'more,,, we use hammer drills to get thru the hard rock ( large aggregate ) in conc,,, mortar mix only needs a carbide tipp'd masonary drill bit.
itsreallyconc is offline   Reply With Quote
Old 10-15-2009, 08:42 AM   #3
gravity always wins
The sand topping should drill pretty easily. Drill on rotary only until you reach the core concrete. Then switch to hammer to finish it. Otherwise, if your hole is close to the edge of the topping, you'll risk a blow out. I assume you are drilling mounting holes for a toilet flange which will be close to the edge of the pipe opening.
Tags
concrete, drilling, tips
More On This Topic
Tools For Building Pergola
Tools For Building Pergola by Expert Village
Okay, this is Bob Street with Houdini Home Improvements on behalf of Expert Village. We are here in Mason, Ohio today and we are going to build a trellis. We've come onto the job site and the concrete fellows had been here before us. They've already... Read More »
When undertaking a home improvement project, you need to know how much concrete you will need and what kind is best for your project. Determining the right amount and kind of concrete you need will save you money and trouble in the long run. Read on to... Read More »
If you are planning a concrete project, you will be dedicating your time and money to making it perfect. Whether you will be doing the job on you own or hiring a contractor, there are a few things you should think about before getting started. While it... Read More »
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, we are going to talk about improper use of a hammer drill. Again, we are talking about a hammer drill today and again, hammer drills are primarily used for drilling... Read More »
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, we are going to talk about the proper use of a hammer drill. Most hammer drills have another feature. This feature is forward and reverse. When drilling into concrete... Read More »
Tips for installing crown molding as a on man job? gmhut Carpentry 3 05-14-2009 08:21 PM
Drilling into concrete walls klycklama Building & Construction 4 02-09-2009 05:07 PM
Tips for HEAVY sink install Sarah24 Plumbing 3 12-04-2008 09:01 PM
Help :( Looking for tips on fishing PEX between floor joists .. drh HVAC 5 05-29-2008 11:26 AM
Need tips for installing/painting moulding BradG Painting 3 02-04-2008 02:44 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
