Old 07-24-2008, 10:21 AM   #1
Sand swirl interior wall finish (Virginia)
Where I live in southeastern Virginia, sand swirl interior wall finish is very common. I'm adding an addition onto my house which will extend the length of the finished room over the garage (FROG). I want to match the texture as closely as possible, but am having trouble nailing down the technique.
When we had our house built, I could have sworn the plasterers used big sponges to spread the plaster/sand mix onto the wall, but the only techniques I've seen documented on the internet use a trowel or brush.
Can you tell me if you are familiar with the brush technique?
Also, what should the ratio of sand to plaster be, and does the drywall need to be primed first?
davetodd is offline   Reply With Quote
Old 07-24-2008, 10:40 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Prime the drywall first.
As far as the amount, or ratio, of sand, that all depends on the texture that you want to match. More sand in the existing texture = more sand in your mix, less = less.
We use a 5 gallon bucket of redimix compound. We add about 7 cups of sand per 5 gallon bucket of compound, and add more if needed. We also add 1 cup of flat latex white paint to the mix.
We do not use the brush to apply the texture, we use a paint roller and pole, to apply it evenly. Grid pattern. We apply a square at about 8'x8' at a time, careful to blend the edges, so as to not leave a defined "ridge", when continuing the application on the next 8'x8' area. We do 8'x8' areas, so as to avoid the mixture drying in the middle of the texture work.
We use a plaster's brush to form 1/2 circles, after the area has the texture rolled onto it evenly... The actual texturing with the brush, is a whole technique, in itself, to get right.
The keys:
Consistent Texture mixtures
Consistent and even thickness-application of the texture material.
Consistent brush-texturing of the applied texture material.
Leave no ridges on the areas.
Practice, practic, practice....on scrap materials, before you attempt it on the walls/ceilings. Get your technique right before.
Old 07-24-2008, 11:22 AM   #3
Thanks for the quick reply. This is very helpful.
Couple of clarifications: What nap of roller would you recommend? Also, is there a particular type of sand that is recommended? I had some brickwork done and the guys left a small pile the they had used to mix the morter with. Since I need such a small quantity, if that sand will work then I won't need to buy another bag.
Will definitely plan to practice on some scrap first.
Old 07-24-2008, 08:01 PM   #4
Any roller will work. Stick with a general-use paint roller cover. We just use the cheapo bulk 6 packs.
Yes: Silica Sand.
No, you must use silica sand. I believe it comes in a 60 pound bag. A drywall supply house, or masonry supply house, should carry it.
Good Luck with the project!
- Build Well -
Old 07-27-2008, 10:59 AM   #5
Eibwen
I to live in southeast Virginia [Virginia Beach] and have had the same swirl texture in several houses and always thought it was done with a brush.
Bout two months ago the AC guy missed a board in the attic and took out about three quarters of a sheet of drywall.
The next day his drywall guy came over to do the repairs. After putting up new board they used USG Veneer Finish [see USG.com] and a few other ingredients and trowled it over the repair area. Then worked in the swirls with a large well rounded damp sponge just like what you would wash your car with. The match was perfect! [cept for it aint been painted yet]
Sammy is offline   Reply With Quote
Old 07-27-2008, 11:16 AM   #6
He was applying a Plaster finish, as opposed to a Drywall material finish.
There are many, many texture patterns in various homes all over the country.
Generally, if it is a swirl, it is done 99% of the time, with a type of brush.
Do we always use a brush to do a swirl pattern, or other similar pattern? No, as stated earlier, every texture is slightly different, like a fingerprint.
Each pro mixes and applies their texture in their own way, with their own slightly deviated technique.
You have to be prepared to "match" by adjusting it, using slight variations of the mixture, the texturing tool, and the technique. That is why every DIYer attempting to match or mimic a texture pattern, should practice, and make the adjustements to get the pattern "just right".
- Build Well -
More On This Topic
How to Texture a Ceiling
How to Texture a Ceiling by Expert Village
This is Kevin at Expert Village. We are going to get a big lump of ceiling texture and apply it. Sometimes we really can't get enough on the roller and if you find you can't get enough on your roller, you need to bring it up and apply it directly. You... Read More »
Alright, this is a really great example of a different kind of texture. We started with that really light texture that we had in the other room, but we added some more mud to this- some plaster on the wall with a trowel to get this look that we wanted... Read More »
Hi, my name is Matthew Christian from Tampa, Florida and on behalf of Expert Village today I'd like to talk to you about a portable electric sander. As I mentioned earlier there are a wide variety of uses for a portable electric sander. In this... Read More »
This is Kevin at Expert Village. The easiest way to apply this texture is with a roller but you may want to use your hands or other means to get enough material on the roller or to get enough material up to the ceiling to roll it out. We are going to... Read More »
It’s been twenty-four hours, I did this yesterday for the purposes of this demonstration and you can see the design here and I think it looks really cool. I did the front and I did the sides here and the next step is going to be the grouting... Read More »
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 07:23 PM
Stair Finish - wood or paint TRM Painting 3 01-16-2008 01:33 PM
Clear Hardwood Floor Finish With Buildup CuCullin Flooring 3 11-18-2007 03:26 PM
cabinet maker's finish jim_k Painting 5 08-03-2007 02:37 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
