-   -   Same old Question basement Insulation advice (http://www.diychatroom.com/f19/same-old-question-basement-insulation-advice-63651/)
rp92285 02-05-2010 01:33 AM
Hi Everybody,
I need your advice in deciding whether or not to keep exisitng insulation
my house was built in 1999, I have a basement with Gaurdian Insulation GLF11 R-11 Perforated fiberglass Rolls 48"X78" on the walls, But no stud frames
Now I am planning to finish the basement, Should I put the stud frame and fill any empty space with another kind of insulation OR remove existing insulation and put stud frames and go for R-13 insulation between the studs?
I am kind of confused, I am reading lot of articles from building science consoritum and could not decide on anything
I live in North NJ, I am yet to get the permit.
Appreciate your help in advicing
Thanks!
ccarlisle 02-05-2010 07:08 AM
Well, ideally, you'd take off the existing insulation and put rigid polystyrene sheets over the exterior walls to create a thermal break, put up a stud wall, fill that with fibreglass then a vapour barrier, then drywall. But your issue is what is touching the concrete and if that can get wet; so sometimes fibreglass against concrete isn't all that good.
If it is really dry back there (and few walls are) then you could build the wall, and fill it with fibreglass...but that moisture issue-leading-to-mould -possibilities is a concern.
Gary in WA 02-05-2010 12:01 PM
http://www.swinter.com/services/docu...Insulation.pdf
Be safe, Gary
