Old 02-12-2009, 10:20 PM   #1
Question
Salt water resistant decks stains
Does anyone have ideas or know of any deck stain products that are salt water resistant?
I have a salt water pool and for the last 3 years I have had to re-stain the deck every summer due to the salt water breaking down the stain.
Have looked through out the net and can't find anything.
The wood on the deck is Cedar.
Any comments or suggestions???
regards M.Lopez
mlopez is offline   Reply With Quote
Old 02-12-2009, 10:44 PM   #2
Remodeling Contractor
Try marine varnish
Old 02-13-2009, 10:30 PM   #3
Originally Posted by Bob Mariani View Post
Try marine varnish
Thanks for the feed back.
Do you have any name Brands. I live in Canada and would have to source local.
Ran into problems ordering stains in the US.
Thanks greatly appreciated.
Old 02-14-2009, 12:01 PM   #4
(the original)
Try Epifanes, Interlux, ZSpar.....at least one of those should be available there. Check with a boat and marine supply house.
Add Sikkens Cetol to that list....I believe they're international.
ratherbefishin' is offline   Reply With Quote
Old 02-14-2009, 01:03 PM   #5
If the deck is stained you might want to restain the deck where it has been bleached out by the saltwater and sun before varnishing. The varnish can then be used over the whole stained deck. So marine varnish, or spar varnish, doesn't break down quite as the polyurethane varnish used for hardwood floors. It is expensive and you'll still need to recoat every couple of years. Maybe take a look at some clear coats intended for decks. Also, Hamilton marine will be able to help you. They are a knowledgable supplier: www.hamiltonmarine.com
willmm is offline   Reply With Quote
Old 09-13-2010, 11:14 AM   #6
PLEASE visit
www.ecomaterialescr.com
regards M.Lopez
CHRISVILLE is offline   Reply With Quote
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 11:53 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
Tankless or tank, but not both gp_wa Electrical 43 10-15-2008 11:08 PM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 09:01 AM
