Saging Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 02:52 PM   #1
Cool
saging floor
I have a house built in the 60's and the floor sags. Its on a 3ft crawl space with cinder block foundation and three 2'x2' cinderblock supports down the center of the house. I plan to jack it up with a 6x6x10 cross beam, and a few bottel jacks. then place 4x4 posts on cinder foundation blocks across the 6x6 about every 5' with U shap nailer plates. will this be good for years to come or will i need to sister the jouist as well. Or am i heading in the right direction?
thevoz is offline   Reply With Quote
Old 01-09-2010, 03:26 PM   #2
jlhaslip's Avatar
Rewards Points: 2,884
I would look to see what those Cinder Block supports are bearing down on. There should be a pad of concrete there to distribute the weight.
Wouldn't it be as simple as jacking and shimming the existing supports? Or is the sag between the supports?
If you do add supports, make sure they rest on good bearing points.
jlhaslip is offline   Reply With Quote
Old 01-09-2010, 04:15 PM   #3
the center supports seem fine, the house seems to sag in a W shape
Old 01-09-2010, 04:17 PM   #4
Old 01-09-2010, 05:39 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,732
Ayuh,.. It sounds like you are,..
Blocking perpendicular to the sag, does the most Good, with the least materials....
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Installing floating floor over squeaky wood floor- rip it up? (Q3) cee2ski Flooring 1 02-09-2009 06:23 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
Attaching 3/4 Sturdy Floor with PL 400 jamiedolan Flooring 1 09-04-2008 09:15 PM
Molde: Underside of Attic Floor stangboy68 Building & Construction 9 12-06-2007 09:53 AM
