Sagging Scissor Trusses - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 11:09 AM   #1
Sagging Scissor trusses
Hi everyone, I'm installing concrete tiles on my roof. The roof isn't loaded yet and the middle scissor trusses are sagging 1-2". Also the house seems the lean westwardly about the distance. It is still in the frame stage ,meaning there is no sheetrock or anything but plywood on the outside. My load bearing walls in the same area look to be sagging also. I have been building slowly as my budget allows, so some exposure to the elements have occurred. Can someone please offer some remedies?
EC1970 is offline   Reply With Quote
Old 01-08-2011, 11:13 AM   #2
Experienced
Jackofall1's Avatar
Might want to get an engineer or a building contractor out to look at that one, sounds like some serious problems with the foundation if it is truely leaning to one side.
Are the supporting walls that the trusses are sitting on level?
The Following User Says Thank You to Jackofall1 For This Useful Post:
EC1970 (01-08-2011)
Old 01-08-2011, 11:21 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,... You've gotta figure out Exactly Where it's failing, before a plan to fix it can be formulated...
Bondo is online now   Reply With Quote
Old 01-08-2011, 11:24 AM   #4
Thank you for ressponing. I have had a structural engineer come and okay the foundation and do some gusset repair to some trusses. He said the rest looked fine. Is there anything I can do?
Old 01-08-2011, 11:27 AM   #5
I'm very new to this. Don't know where to look. The supporting walls seem to be level but the interior surely aren't. ???????
Old 01-08-2011, 11:31 AM   #6
KemoSabe
loneframer's Avatar
You can't blame the failing structure for bad framing, you blame the bad framing for the failing structure.
I'd like to see pictures of the entire structure, as well as more detailed photos of problem areas.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
EC1970 (01-08-2011)
Old 01-08-2011, 11:32 AM   #7
Experienced
Jackofall1's Avatar
Pictures would be very helpful in this forum
Old 01-08-2011, 11:34 AM   #8
Not real savvy with technology but I will try my best to send pictures.
Old 01-08-2011, 12:03 PM   #9
Framing Contractor
Sagging 1-2" is the biggest RED FLAG and the job should be stopped. Have you put a level on the walls to see if the are plumb?
Is he the one that designed the trusses? If not who drew you plans and designed them?
Where are the trusses sagging, in the middle, on the outside wall?
Again, put a level and check for plumb. The framer should stop framing right now until all of this is corrected or it sounds like your trusses can fall down like dominoes with the rest of your house.
Asking you about truss bracing won't matter because you will not know if they are properly braced. You have to have whomever designed the trusses come in and the building inspector come in to make sure this house is safe.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
EC1970 (01-08-2011)
Old 01-08-2011, 12:17 PM   #10
so you know in case you don't, plumb is a vertical measurement- if your wall is leaning it is out of plumb. Level is horizontal, if your wall is sagging it is out of level. Are these site built truss or fabricated in a truss factory? If factory built get fabricator out there if all bearing walls are plumb and level
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
EC1970 (01-08-2011)
Old 01-08-2011, 07:09 PM   #11
Thank you for your concern. We have stopped the job and I will call the inspector Monday morning. Maybe he will catch something the engineer didn't. The trusses are sagging in the middle but only the scissor trusses. Incidentally, all the scissor trusses are doubled up. All trusses are factory made and all 2x4 constructed. The first 8 trusses are braced from the outside wall on both sides. The outside walls seem to be level. I used a 4' level.
Old 01-08-2011, 07:25 PM   #12
KemoSabe
loneframer's Avatar
Are you sure the scissor trusses are sagging? Is it possible that they were not built properly to begin with and don't match the adjacent trusses?
Please elaborate on the conditions that define "sagging".
Old 01-09-2011, 04:31 AM   #13
IHICH2011's Avatar
Wow...You must have one heck of a span or pitch to have 2x Ply trusses.
I am "Happy" to hear you stopped!!
Be careful!!!!...Too many people get injured or worse every year from not bracing walls and especialy "Trusses"
When trusses go down..It will happen in less than 1-3 seconds.
Yes..That fast.
Good Luck!! We are all wishing you the "BEST" I sure hope this is an easy Fix!! Things will get Better!! Your New Home will get built!!
Mike - IHICH2011 - I Hope I helped!
IHICH2011 is offline   Reply With Quote
Old 01-09-2011, 07:11 PM   #14
Tizzer's Avatar
Rewards Points: 452
I see a lot of red flags in this project given the info you provided. Are framers doing this project? How come you spotted the "sag" and not them.
Why the added gussets? Were these trusses designed for concrete tiles?
The "sagging" could be from the framers not aligning the top cord to a string line. Run a string line across the top/middle and see what happens. Without seeing the truss layout drawing,those scissor trusses may have been installed wrong.
Both gable trusses need to be dead nuts plumb. If the framers pulled layout measurements off an out of plumb gable, it'll look like its leaning because it is.
A 4ft. level won't do it. You could be trying to plumb off a stud with a bow in it.
How high is the top of the roof? Can you or the framer shoot a laser down the gable wall? Plumb bob?
Tizzer is offline   Reply With Quote
Old 01-11-2011, 09:35 PM   #15
Framing Contractor
What happened on Monday with the inspector?
Joe Carola
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 01:15 PM
Sagging 2 x 6 rafters on a 4:12 pitch Kerins Woodwork Roofing/Siding 7 11-29-2009 07:10 PM
Sagging Roof nayak143 Roofing/Siding 15 06-12-2009 02:03 PM
Sagging roof? Please help! caliwildman Roofing/Siding 7 03-30-2009 12:09 PM
Urgent advice needed on sagging roof for home I'm buying jwoair23 Roofing/Siding 6 02-20-2007 12:17 PM
